Home > Technical (L322) > Is Revive a "snake oil" con? |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
There are a few YouTube videos and all seem to suggest it works.
5th May 2019 8:08am |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 |
I have sticky vanes in my 2.4 puma 90. I tried fuel additive over 1000 miles, no difference.
5th May 2019 7:18pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Tbh, when you need 2 bottles at £35-40 each I"d pay the extra for a terraclean. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
5th May 2019 8:00pm |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 |
Hmm, Terraclean, I had also thought about this, but know a guy who`s Mondeo was never the same afterwards, and not in a good way. I would be interested if anyone has has any good experience of Terraclean or HHO cleaning. |
6th May 2019 4:57pm |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
Mmm? I'm sceptical still to be honest. I can't get my head around Revive fluid surviving the cylinder ignition temps to then continue to travel through exhaust valves and through and over turbo blades in a split second but still managing to remove crud, surely all that's seen emerging from exhausts is just steam? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
6th May 2019 5:38pm |
I regularly use Dipetane. Came across it when I had problems with the fuel pressure regulator sticking. I was told the only fix was a new high pressure fuel pump at €1200 + labour. I asked SWMBO to get some injector cleaner thinking I had nowt to lose and she came home with Dipetane. I put in the tank and gave the fatty an Italian tune over 30 miles or so. Problem solved. 18 months later it's still going well.
8th May 2019 1:44pm |
I ran the revive treatment yesterday. Hard to tell any massive differences yet but the throttle response seems a little better. Seems to pick up quicker. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
9th May 2019 1:29pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Haven't tried diptane in the RR but used it in a truck engine and worked wonders re the emissions 2015 4.4 AB
9th May 2019 7:21pm |
Why do you need two bottles? Cheers
11th May 2019 7:41am |
