Home > Maintenance & Mods (L405) > Front brakes squealing under slow braking.......
CUE99T
Esteemed RR chums........my newish brakes recently added seem to make a lot of noise but only under 5mph the brakes squeal a lot, any ideas???
P all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #514892 10th May 2019 3:40pm
duckworthparts
Site Sponsor
What brakes did you fit? You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #514894 10th May 2019 3:53pm
GGDR
I would question the fitting and not the pad - squealing is usually due to lack of grease on the back of the pad.
Perhaps they did not do it correctly or put enough on?
. Cheers, Greg
Post #514896 10th May 2019 4:14pm
CUE99T
I fitted Brembo brakes with the same part number from JLR on the website
Eurocar parts part numbers - not sure if they are the same elsewhere
PADS - 10167027A
DISC - 10467037A
PAD KIT - 107670188 all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #515294 14th May 2019 10:27am
there have been many threads re the pros and cons of fitting aftermarket pads....i personally would only fit OE..
Post #515302 14th May 2019 12:32pm
CUE99T
These are OE pads....its what are used on JLR dealerships.....I even checked the part numbers with Taggarts and Brembo website and ECP. all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #515307 14th May 2019 2:32pm
brembo dont actually make pads....unscrupulous peeps use their brand name...
OE pads are normally JURID..
Post #515315 14th May 2019 3:07pm
Mikey
There is a TSB for squealing brakes. Involves filing a 45 degree angle into the top edge of each brake pad Laughing
And Jurid are the OEM supplier Thumbs Up
Post #515347 14th May 2019 8:19pm
