Home > Maintenance & Mods (L322) > hawkeye to buy or not to buy
Page 1 of 3 123>
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i have a icarsoft i930
i have a fault on the air suspension, it says CAN bus fault
what that means i have no idea
i have an hawkeye set up for a defender
to up grade it to a RR, its about the same price as a buying a new one
the new hawkeye BA5068 covers most if not all land rovers except for the latest ones
the BA5068 can be bought off Ebay for less than $700
the GAP IID BT, which is highly recommended on this site buy some members, can be bought for about the same money
so, as the hawkeye covers most land rovers, while the GAP tool is vin locked, i think the hawkeye is the better deal
but is the hawkeye as good as the GAP tool
dose any one know
after spending $700 on which ever, will i get the same result i am getting from my icarsoft, CAN bus fault
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #514840 10th May 2019 5:47am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Do you have the i930 or the i980 (just checking it isn't a typo). My quick search shows the 980 as a Mercedes reader so it may only show generic OBD codes for other makes. My i930 while not as capable or easy to use as as my IID tool will give you the specific error code as is a dedicated LR reader. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #514845 10th May 2019 8:35am
knares
yes you are right, i just corrected that.
Post #514853 10th May 2019 9:55am
MikeO
Do you get a specific fault code? 2016 Skoda Octavia VRS Estate
Post #514855 10th May 2019 10:36am
If you are planning to keep the car, or stick with Range Rovers / Land Rovers - then iiDTool / AllComms (for your current model) is the way to go. If not then the more generic tools like Hawkeye / Solus / Autologic may solve most issues. .
Post #514857 10th May 2019 10:53am
knares
no i dont think i do, i wrote all the fault codes down for the ABS but i haven't got one wrote down for that RR 2005 4.4 petrol
Post #514871 10th May 2019 1:07pm
knares
at this stage, yes, i do plan to keep the car RR 2005 4.4 petrol
Post #514872 10th May 2019 1:09pm
MikeO
In answer to your question, I don't think the IID can give you any more info on an error code than the i930. The IID is far more capable and definitely worth the money but I'm not sure it will help you isolate this particular problem. 2016 Skoda Octavia VRS Estate
Post #514928 10th May 2019 9:15pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
You'll need to fix the canbus issue first Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #514931 10th May 2019 9:33pm
knares
Hmmmmmmmmmmm RR 2005 4.4 petrol
Post #514968 11th May 2019 10:35am
Essex1959
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Take a look here https://www.rswsolutions.com/index.php/mki...-bus-fault it may help
Post #515571 17th May 2019 8:39am
knares
thats interesting.
one of the wheel speed sensors is showing open circuit
i am waiting for one to be delivered now RR 2005 4.4 petrol
Post #515578 17th May 2019 10:45am
Essex1959
I reckon that will be the solution
Post #515582 17th May 2019 11:33am
knares
hears hoping RR 2005 4.4 petrol
Post #515607 17th May 2019 2:13pm
Essex1959
Post #515612 17th May 2019 2:33pm
Page 1 of 3 123>
