Home > Technical (L322) > tranmission fault limited gears in slow moving traffic only
Dustbolt
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Santorini Black
Hi, for some reason, occasionally, in slow moving trafffic (ie low gears, slow speed, stop/start) I get a "transmission fault - limited gears" message. If I switch off, go into P, give it a minute and start up again, everything is fine.
The first time I thought, oh, its the gearbox, but actually the gearbox is fine, changes smoothly, finds gears ok. Also, i can't trigger this error to come on if I try - it seems to be some quirk combination of hot engine, low gears, switching between D/N, stop/start, on and off the break pedal that seems to make it get confused or something.
Maybe some kind of ECU or sensor error, mechanically everything seems fine, and after "resetting" again its fine again.
This only happens in creeping traffic. Just wonder if anyone had this same issue, and got to the bottom of it?
Any words of wisdom will be much appreciated!
(4.2 S/C 2005)
Post #514265 4th May 2019 5:19pm
Dolphinboy
Maybe new radiator required. The bottom levels get gunked up and this is where the tranny oil cooler is run off from (in some models. Can’t say it’s the same in yours)
Post #514304 4th May 2019 10:12pm
RRPhil
How old is your battery?
Phil
Post #514341 5th May 2019 9:30am
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
same year as mine did the same with a failing battery Thumbs Up
Post #514344 5th May 2019 9:49am
Dustbolt
The battery is a top of range bosch one only 6 months old, so if it's electrical it's to do with circuitry rather than failing battery. Also if I do diagnostics it doesn't seem to have logged as a proper fault.
Post #514350 5th May 2019 10:53am
Dustbolt
Also it can happen before the engine/gearbox has had time to heat up, although I will investigate the radiator option further.
The thing that it seems to coincide with most is low speed and low revs in D and frequent changes to N. All of a sudden Bong! Bong! Bong! Stop, switch off, P, start up, back to normal.
Post #514352 5th May 2019 11:06am
RRPhil
The radiator/overheating issue was on 5-speed vehicles.
Does the error message consistently appear just when you move the gear lever e.g. indicating a gear position/inhibitor switch fault on the Mechatronic unit?
Do you frequently select Neutral when you’re in stop-start traffic, rather than leave it in ‘D’ with your foot on the brake?
Phil
Post #514362 5th May 2019 12:22pm
phil, slightly off topic and re your last statement, is it preferable to leave in 'd' in stop/start traffic?
Post #514363 5th May 2019 12:28pm
RRPhil
Just personal preference, really. I must admit that I can’t be bothered to select neutral for short stops. It doesn’t matter to the transmission if you leave it in ‘D’ because the turbine shaft is stationary, so the running gear doesn’t see any fatigue cycles. The additional thermal load on the fluid from the stalled converter is trivial at tickover. The downside is a slight penalty in fuel economy (as the engine idle speed control has to fuel the engine to overcome the additional converter drag) and annoying the driver behind you with your brake lights! The later 8-speed boxes introduced Neutral Idle Control to automatically disengage gear if the car was stationary with the driver’s foot on the brake, to improve fuel economy.
In Dustbolt’s case I just wondered if it might be worth experimenting leaving ‘D’ selected, and not moving the gear shift into neutral when you stop, to see if this prevents the error message from coming on.
Phil
Post #514368 5th May 2019 1:15pm
excellent, thank you phil.....
Post #514369 5th May 2019 1:21pm
Dustbolt
Hi Phil, thanks for taking the time to reply.
Yes I tend to put it in N in stop start traffic conditions, just because I had a vague idea D plus break pedal was bad somehow. I will just leaving it in D from now on in those conditions and see if it ever happens again. If that fixes it, it would seem to suggest the mechatronic switch is root causes.
Post #514375 5th May 2019 3:55pm
