Home > Technical (L322) > tranmission fault limited gears in slow moving traffic only |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3167 |
Maybe new radiator required. The bottom levels get gunked up and this is where the tranny oil cooler is run off from (in some models. Can’t say it’s the same in yours) |
4th May 2019 10:12pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
How old is your battery?
5th May 2019 9:30am |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 602 |
same year as mine did the same with a failing battery |
5th May 2019 9:49am |
Dustbolt Member Since: 09 Dec 2018 Location: London Posts: 12 |
The battery is a top of range bosch one only 6 months old, so if it's electrical it's to do with circuitry rather than failing battery. Also if I do diagnostics it doesn't seem to have logged as a proper fault. |
5th May 2019 10:53am |
Also it can happen before the engine/gearbox has had time to heat up, although I will investigate the radiator option further.
5th May 2019 11:06am |
The radiator/overheating issue was on 5-speed vehicles.
5th May 2019 12:22pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
phil, slightly off topic and re your last statement, is it preferable to leave in 'd' in stop/start traffic? |
5th May 2019 12:28pm |
Just personal preference, really. I must admit that I can’t be bothered to select neutral for short stops. It doesn’t matter to the transmission if you leave it in ‘D’ because the turbine shaft is stationary, so the running gear doesn’t see any fatigue cycles. The additional thermal load on the fluid from the stalled converter is trivial at tickover. The downside is a slight penalty in fuel economy (as the engine idle speed control has to fuel the engine to overcome the additional converter drag) and annoying the driver behind you with your brake lights! The later 8-speed boxes introduced Neutral Idle Control to automatically disengage gear if the car was stationary with the driver’s foot on the brake, to improve fuel economy.
5th May 2019 1:15pm |
excellent, thank you phil..... |
5th May 2019 1:21pm |
Hi Phil, thanks for taking the time to reply.
5th May 2019 3:55pm |
