Home > In Car Electronics (L405) > Tracker
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
Tracker
Topix says I have a tracker. How do you go about activating these?
Post #514216 4th May 2019 2:00pm
CS
The landrover.co.uk website has a section on In Control Secure which will tell you what you need to do, and once done, you can download a certificate if your insurers want that. Some insurers seem used to the idea of trackers being an addition which is installed on an existing vehicle, rather than built in from the start as is the case with the RR, and one has explain the position before they will accept the LR certificate. Only Range Rovers since 1988
Post #514219 4th May 2019 2:09pm
Felstmiester
Thanks. Any idea on cost? I’ve found it on the website but there’s no information regarding fees.
Post #514226 4th May 2019 2:28pm
CS
It seems to be a case of asking a LR dealer. Mine is still within the initial period covered in the purchase price. Only Range Rovers since 1988
Post #514229 4th May 2019 2:49pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Its about £250 iirc
Post #514322 5th May 2019 8:33am
fin
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
So had mine and a sticker on the front of my service book to say one was fitted but Tracker couldn’t find detail of it and I gave up, for anyone buying trackers reading this post always be mindful that you review the ongoing subscription costs as some can be initially cheep to buy them however expensive to run year on year and you end up worse off.
Post #514386 5th May 2019 7:00pm
