![]() | Home > Maintenance & Mods (L322) > Indecisive Transmission on L322 (BMW RR Vogue) |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
How sure are you that your transmission is shifting gear? Could it not be the torque converter lock-up clutch that you’re feeling?
BIRDY57 Member Since: 24 Oct 2016 Location: Nottingham Posts: 22 ![]() ![]() ![]() |
Hi, obviously can't say for definite but the symptoms are very similar to the one's my 2006 TD6 had and I ended up having the gearbox and torque converter refurbished. These boxes are "sealed for life" supposedly and for years you couldn't get a service kit. These are now readily available, but maybe the damage has been done on yours?
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
Select the 4x4 Info screen on the centre console display and check that the Hi/Lo ratio indication isn't flipping between Hi and Lo due to a problem with the transfer box motor potentiometer (or associated wiring). If the ECU thinks it's in Lo ratio then it disengages the torque converter lock-up clutch, so if its flipping between Hi and Lo then the clutch disengages then engages again then disengages, and the RPM jumps about accordingly. |
Gary Williams Member Since: 17 Jan 2017 Location: Essex Posts: 54 ![]() ![]() ![]() |
Hi Guys,
When was the transmission (gearbox) oil / and the transfer box oil last changed ? .
Hi Joe90,
Hi Guys,
As RRPhil suggested, sounds like the torque converter lock up clutch @ 50mph .
