Home > Technical (L322) > Gearbox Overheating Message |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
I would be looking into getting the gearbox oil changed, even despite the very low mileage.
24th Apr 2019 10:57am |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
I have had the gearbox overheat message a couple of times over the last 7 years , appears to be totally random and of no consequence at all as it clears after restarting the vehicle , so i suggest a sensor having a paddy , unless it happens often then i would not be concerned. |
24th Apr 2019 11:25am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
I had this problem a couple of years ago, its most likely the main radiator bottom rows blocked (known fault).
24th Apr 2019 11:40am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
Seeing as you’re close by, I wonder if it might be worth you stopping by Valve Bodies UK (Claremount Road, Wallasey) and asking Pete Stirrup if their brand-new Hydra-Test machine can test the temperature sensor on your Mechatronic unit? I’m not sure if they have an 8HP70 adaptor plate for it.
24th Apr 2019 7:24pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
I remember Northernmonkeyjones had an overheat message on his 2011. He did a fluid and pan change and seemed to fix it. Drop him a PM to confirm I've got it right.
24th Apr 2019 9:23pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
24th Apr 2019 9:43pm |
Nice one Mark
24th Apr 2019 9:51pm |
CMC15 Member Since: 15 Mar 2019 Location: Wirral Posts: 20 |
Thank you for the information guys, very much appreciated.
26th Apr 2019 11:05am |
nambFFRR Member Since: 06 Aug 2018 Location: United Kingdom Posts: 191 |
I had the same message last weekend- mines a 2011 4.4TDV8 Vogue SE with 53k miles. Plugged the obdm gizmo in and the fault code said the sensor indicated a high temp. Strange as I’d just started my journey so the oil temp was at ambient or just above.
30th Apr 2019 9:35pm |
problem has never recurred on mine, I do think its a sensor glitch, but to replace the sensor is problematic.
30th Apr 2019 10:20pm |
Ouchio!! |
30th Apr 2019 10:27pm |
PraguePrado Member Since: 09 May 2022 Location: Paris Posts: 27 |
Regarding service bulletin LTB00080, I notice it's from Aug of 2007 (and it gives affected VIN numbers). Would that indicate that this problem was definitely sorted after that last VIN, and any L322 produced after that date isn't affected by this radiator blockage issue? Is is that just wishful thinking? I've got a 2009 3.6 TDV8 and am trying to narrow down what parts I need to throw at it.
11th Jul 2022 1:02pm |
