Home > Technical (L322) > Gearbox Overheating Message
CMC15
Hi guys, hoping you can assist. Had my FFRR for around 6 weeks now and has been faultless, until yesterday. Car is 2011 4.4TDV8, 38K miles.
After a steady 70mph cruise back from Manchester airport to the Wirral, roughly 40 miles, just as I got off the motorway I pulled the flappy paddle to downshift. Car wouldn't manually downshift and immediately came up with the orange 'Gearbox Overheating' message.
I pulled over and turned the car off immediately. Checked under the car, no leaks, noises or hot smells. Started the car again after about 60 seconds and drove home, about 2 miles at 40mph with no error messaged again.
Also, looking at the radiators/oil cooler, no visible impact damage or leaks.
Drove the car yesterday, whilst using the command shift and giving the gearbox a bit of a workout for the whole drive with no issues, smells, leaks etc.
Is this likely to just be a random sensor reading or does this sound like something more sinister?
Thanks in advance, Chris
Post #513007 24th Apr 2019 11:47am
Baltic Blue
I would be looking into getting the gearbox oil changed, even despite the very low mileage.
It is possible that a previous owner has used it to do a lot of heavy towing.
Post #513010 24th Apr 2019 11:57am
gavinn
I have had the gearbox overheat message a couple of times over the last 7 years , appears to be totally random and of no consequence at all as it clears after restarting the vehicle , so i suggest a sensor having a paddy , unless it happens often then i would not be concerned.
Post #513015 24th Apr 2019 12:25pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I had this problem a couple of years ago, its most likely the main radiator bottom rows blocked (known fault).
See below!
Get the radiator checked out or replaced and also the Transmission Oil cooler.
This is the data from Land Rover.
Land Rover issued a Technical Service Bulletin in September 2007 for "High Engine Speeds and/or Transmission Shift Problems" which stated :
"The customer may experience high engine speeds and/or transmission shift problems after driving for 25 minutes or longer. There may also be the possibility of the transmission overheat message being displayed on the instrument cluster. High transmission fluid temperatures may be the cause of the problem"
In other words the transmission is selecting 'cooling strategy' mode as the bulk oil temperature has exceeded 140 deg. C.
The fault is caused by a partial blockage in the lower eight tubes of the (engine) radiator which supply coolant to the transmission oil cooler - supposedly caused by "depletion of the coolant corrosion inhibitor".
The bulletin states that it's not possible to clean out the partial blockage and that the radiator must be replaced.
LTB00080 - 15 Aug 2007
VIN Numbers 100042-175505
This is one of the forum threads
http://www.fullfatrr.com/forum/topic27376-15.html
http://www.fullfatrr.com/forum/topic2438.html
(may not be the above as yours is a newer model!!)
Post #513017 24th Apr 2019 12:40pm
RRPhil
Seeing as you’re close by, I wonder if it might be worth you stopping by Valve Bodies UK (Claremount Road, Wallasey) and asking Pete Stirrup if their brand-new Hydra-Test machine can test the temperature sensor on your Mechatronic unit? I’m not sure if they have an 8HP70 adaptor plate for it.
Phil
Post #513084 24th Apr 2019 8:24pm
GGDR
I remember Northernmonkeyjones had an overheat message on his 2011. He did a fluid and pan change and seemed to fix it. Drop him a PM to confirm I've got it right.
. Cheers, Greg
Post #513095 24th Apr 2019 10:23pm
Dropped the oil and pan.
Not had the message come back. There is nothing that can't be fixed with a hammer😜😜
Post #513097 24th Apr 2019 10:43pm
GGDR
Nice one Mark Thumbs Up
. Cheers, Greg
Post #513098 24th Apr 2019 10:51pm
CMC15
Thank you for the information guys, very much appreciated.
I've been driving around for a few days with no issues so hoping it is just the sensor having a wobble but i'll be keeping a very close eye on it.
Cheers
Post #513265 26th Apr 2019 12:05pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
I had the same message last weekend- mines a 2011 4.4TDV8 Vogue SE with 53k miles. Plugged the obdm gizmo in and the fault code said the sensor indicated a high temp. Strange as I’d just started my journey so the oil temp was at ambient or just above.
I recorded the error code and did a reset. Over the weekend, no other codes popped up and clocked up around 100miles of mixed driving. So far no further error code has been displayed. I’ll keep my eye on it over the coming days, weeks, months....as my old dad who was a top mechanic on cars through to HGVs used to say “it’ll develop, son!”
Post #513779 30th Apr 2019 10:35pm
problem has never recurred on mine, I do think its a sensor glitch, but to replace the sensor is problematic.
Its integrated in the gearbox loom and is not a separate item. changing the sensor would involve changing the whole wiring harness in the box. Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #513789 30th Apr 2019 11:20pm
nambFFRR
Ouchio!!
Post #513790 30th Apr 2019 11:27pm
PraguePrado
France
Regarding service bulletin LTB00080, I notice it's from Aug of 2007 (and it gives affected VIN numbers). Would that indicate that this problem was definitely sorted after that last VIN, and any L322 produced after that date isn't affected by this radiator blockage issue? Is is that just wishful thinking? I've got a 2009 3.6 TDV8 and am trying to narrow down what parts I need to throw at it.
Many thanks.
Post #636656 11th Jul 2022 2:02pm
