Home > Technical (L322) > Air Con Compressor - how much oil?
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Hello all,
Does anyone know how much oil the air con compressor system/pump should hold normall?
Or direct me to where I can find out? - thanks!
2012 L322 4.4 TDV8. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #513688 30th Apr 2019 2:02pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Fairly sure there's a label under the bonnet Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #513689 30th Apr 2019 2:06pm
TDV8_Tommy
Here's the label listing the gas quantities, unless I can't read, where's the oil info?
Does the '+' indicate the oil, or the max + gas amount? 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #513691 30th Apr 2019 2:13pm
Bushy30
I was sure it was there -- apologies -- have a look on page 2 here: -
http://ishop.cooldrive.com.au/ts1549946340...Online.pdf Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #513694 30th Apr 2019 2:28pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Mate, pay someone with the right gear and knowledge to do it. Get it wrong and it will cost a lot more. You can overcharge the system and do damage.
The 700g is the amount of gas in grams the system needs for front only. 880g for front and rear system. The plus or minus is the tolerance the system allows. Ie. 690 g to 710g is within the range.
PAG SP10 is the oil type and its normally around 50ml of oil but it varies. If you blow the compressor you will need a new one + evaporator and drier and labour and it will relieve you of a grand.
Forgive me being blunt but your questions indicate that you don't really know what you are doing and on air con systems that gets expensive but its your choice. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #513698 30th Apr 2019 2:51pm
TDV8_Tommy
Not blunt, just unhelpful assumptions.
If you read my question I asked how much oil is normally in the system...nothing more.
My mechanic drew out alot of oil, far more than what he expected which may explain why the system not working as well as it should. I've no plans in touching the system mysef. Removal of this seemingly excessive oil enabled the system to blow icy cold whereas before it was not and was temperamental.
And as we can't find how oil it should hold...hence my question. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #513700 30th Apr 2019 3:04pm
when you say 'oil' do you mean 'air con gas' ????
Post #513701 30th Apr 2019 3:05pm
TDV8_Tommy
No, actual oil additional and separate to the gas/refrigerant which is apparently as equally important to get right as the gas itself and does have an impact if it's overfilled or underfilled. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #513702 30th Apr 2019 3:07pm
Bushy30
Did you read the pdf? there's a calculation on page 2! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #513704 30th Apr 2019 3:09pm
TDV8_Tommy
I did and thank you for posting!
I shall dive into it when I've some time later. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #513706 30th Apr 2019 3:13pm
Grofus
My apologies for the assumptions. I just didn't want you to make an expensive mistake and do a diy job.
The oil amount is dependent on the compressor type and manufacturer. I believe it to be a Sanden. It might show the oil amount on the compressor label.
Your problem is you dont know how much oil is left in the system as well as not knowing the total amount needed.
It might be worth flushing the system to start from scratch and find out from sanden the oil amount needed.
I hope that is more helpful Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #513708 30th Apr 2019 3:20pm
TDV8_Tommy
Thanks, Grofus! Thumbs Up
LOL, no plans on working on it myself, being in rural Spain miles from the main dealer I've got a good mechanic but he's no L322/RR guru...no one in these parts is!
We are going through a conservative process of elimination with the hope of avoiding to do a compressor replacement. We've confirmed there are no leaks. If the oil route (for whatever reason) is not an option then its new compressor. But, last night it ran like a dream so hopefully removing the excess oil *may* have done the trick.
Cheers 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #513710 30th Apr 2019 3:25pm
Grofus
Ok mate. Makes you wonder why there was so much oil in it. As you know it causes as many issues as not enough.
My advice as its working. Do a full recovery and flush, then recharge with correct charge weight and oil amount. You will need to do that if the compressor goes pop anyway plus other bits mentoined earlier. So i guess we are back to your first question, lol, how much oil. Rolling with laughter
I would go on the Sanden website and ask them. Thumbs Up
The other option is leave it and chance it. Be lucky. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #513712 30th Apr 2019 3:37pm
