Home > Technical (L322) > Smokie TD6? |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
i have no experience on remapped vehicles but others on here do , also i find when i do short runs ore low speed use if i accelerate hard using the kickdown i get black smoke which i know is just overfuelling but i will be corrected if im wrong could just be a build up of soot but probably best to get it checked onto no6 Range Rover
23rd Apr 2009 4:07pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
Its not supposed to be like that. There are remaps and remaps. Some cheap engine tuners just alter the fuel system and all this does is dump excess fuel into the engine.
24th Apr 2009 9:00am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
Yes, here I am!
24th Apr 2009 10:12am |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Guys many thanks.Most probably i will follow RRUK advice and return back to normal although for the remapping LR workshop charged me euro 1000 and supposed was a "friendly" price (i donot want even to think how they treat their enemies).But as i said the most annoying is that car is getting smokie even during normal accelation.
27th Apr 2009 9:05am |
Akis,
27th Apr 2009 11:05am |
27th Apr 2009 2:16pm |
shaun10569 Member Since: 20 Oct 2009 Location: lancashire Posts: 13 |
could be the turbo seal starting to fail , this is the first sign...check the oil level and round the tailpipes for a wet deposit instead of a dry one when the car is at operating temp...my 03 td6 just had a turbo at 107k and those were the symptoms...all fine now |
22nd Oct 2009 11:58am |
jope Member Since: 04 Apr 2009 Location: Reinsvoll Posts: 43 |
have you changed the valve breather filter? This can cause smoke if it'snot beeing changed. In the first service manuals for the td6 there is no information about changing this filter. But at BMW the filter is recomended changed min every 30 000km |
22nd Oct 2009 12:39pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 766 |
Where is this valve breather filter please? |
22nd Oct 2009 6:05pm |
At the engine you can see two black plastic circles, that's where the filter is...
22nd Oct 2009 6:37pm |
I have a diesel. Does it have a valve breather filter too? |
23rd Oct 2009 7:09am |
the picture shown is from my car that is a 2002 td6 (diesel ) |
23rd Oct 2009 11:15am |
ive changed mine recently it comes as a kit filter with O rings / seals youll need torx bits to do the job AND DONT DROP ANYTHING INTO THE ENGINE takes about 15 minutes on a nice sunny day onto no6 Range Rover
23rd Oct 2009 4:45pm |
Never have listened abt valve breather filter.I have already order it.Many thanks |
3rd Nov 2009 4:35pm |
