Home > Technical (L322) > Smokie TD6?
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
In Microcat the valve breather is called filter assy, part no. 8510298. I wonder if it's the same as the BMW part no. 11127799224?
Post #8223 3rd Nov 2009 6:07pm
adara
Found the part from BMW, it's no. 11127793163.
Took me 1 hour to replace, most of the time hunting the fallen bits... I think one can safely replace only the felt filter, it's half the price of the whole assembly, which costs 46 EUR...
Post #8280 5th Nov 2009 10:09pm
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Hi guys.Thanks to all and mainly to jope.Changed the breather filter and car now smokeless.
So simple and noone of the two f.... official RR workshops i have visited were able to find it.
Since i changed filter by my self so i ve got an idea thinking now to also clean egr valve as a further precaution.
Once again many thanks for the great assistance.
Post #8682 24th Nov 2009 1:02pm
jope
Norway 2003 Range Rover HSE Td6 Java Black
hi thats great Thumbs Up Thumbs Up
happy to contribute on this great forum
Post #8683 24th Nov 2009 1:04pm
jayro
Australia 2003 Range Rover HSE Td6 Stornoway Grey
I too had issues loosing bits and used bluetac to hold the socket set and Hex head from falling...
My Breather was soaked in oil -after 285k I guess it was going to be dirty but soaked it oil was a surprise ! Haven;t had a chance to drive it yet.
Previously I blocked the EGR with a small piece of metal I cut myself which made at least 2litres per hundred gain in fuel efficiency and motor sounds much better and I think runs better. Definitely worth doing and for the effort of cutting a small metal disc yourself a cheap way to get results.
Now to take off the manifold and clean that !!
Post #161460 3rd Jan 2013 7:52am
My TD6 is in standard tune but doesn't smoke at all even when booting it. I'd try a fuel injector cleaner and possibly squirt some fairy liquid up the exhaust and then fill it with water and leave it a few hours to eat at the soot. Then start the engine and don't touch the accelerator.
As you crank over it will clear the major part of the water and crud out and then spit water out for a little while and steam off the rest. Helps with a lot of smokey diesels that have sooted up exhausts from careful drivers who never give it the occasional boot.
As above though it also sounds like your remap is bad and hasn't been done right to be overfuelling so much. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #161466 3rd Jan 2013 9:11am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Should have replaced with Pt No 11127799367. Updated part . Never have to replace again.
Gary
Post #161591 3rd Jan 2013 1:36pm
ahebron
New Zealand
I have posted about this before so a search will help you.
When I was fitting the EGR blank I removed the inlet manifold from my TD6 and washed out the 5mm of black soot that had built up inside. My car would create smoke screens that would have made 007 jealous. No smoke once that job was done but by crikey it was a filthy job.
Adrian VW Amarok 2014 Highline auto
Post #162347 7th Jan 2013 5:39am
frikkadel
South Africa
kingpleb wrote:
My TD6 is in standard tune but doesn't smoke at all even when booting it. I'd try a fuel injector cleaner and possibly squirt some fairy liquid up the exhaust an..................................................
Brake fluid in the exhaust is much better. Burns the soot out but only when hot. people will think your engine has blown with the amount of smoke.
Post #399897 10th Aug 2016 7:21am
