![]() | Home > Technical (L322) > Throttle body problem.. |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
workshop manual does say reset adaptations after new part has been fitted.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
The only diagnostic equipment i have is an IID tool.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
page 112 of the IID manual: -
Replaced throttle body but it's made no difference. |
Did you manage to clear the adaption values? Current: 2011 FFRR Vogue SE 4.4 TDV8
No, couldn't find the reset capability on my iid ... |
Assuming you cleared the fault codes with your iid? |
You say the car won’t idle or rev. What does it actually do? Starts ok just won’t idle steadily and hunts around? Or something else? |
It starts, runs rough, idle fluctuates between 1500 and 200 revs and doesn't respond to any throttle input.
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
Any chance to try different CPS ? |
Have you had a look at the MaF sensor? Is it filthy?
from the manual: -
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 165 ![]() ![]() ![]() |
I know this thread is from a while ago, but Steptoe - did you get to the bottom of this and if so, what was it?
The problem just disappeared. I bought a used throttle body/TPS and fitted it but it made no difference.
