Home > Technical (L322) > Throttle body problem.. |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 |
workshop manual does say reset adaptations after new part has been fitted.
26th Apr 2019 1:31pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
The only diagnostic equipment i have is an IID tool.
26th Apr 2019 3:06pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
page 112 of the IID manual: -
26th Apr 2019 3:54pm |
Replaced throttle body but it's made no difference. |
1st May 2019 11:28am |
Did you manage to clear the adaption values? Current: 2011 FFRR Vogue SE 4.4 TDV8
1st May 2019 11:30am |
No, couldn't find the reset capability on my iid ... |
1st May 2019 11:51am |
Assuming you cleared the fault codes with your iid? |
1st May 2019 11:52am |
You say the car won’t idle or rev. What does it actually do? Starts ok just won’t idle steadily and hunts around? Or something else? |
1st May 2019 11:53am |
It starts, runs rough, idle fluctuates between 1500 and 200 revs and doesn't respond to any throttle input.
2nd May 2019 12:39pm |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Any chance to try different CPS ? |
2nd May 2019 3:35pm |
Have you had a look at the MaF sensor? Is it filthy?
2nd May 2019 5:41pm |
from the manual: -
3rd May 2019 12:03pm |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 162 |
I know this thread is from a while ago, but Steptoe - did you get to the bottom of this and if so, what was it?
29th Aug 2021 6:27am |
The problem just disappeared. I bought a used throttle body/TPS and fitted it but it made no difference.
31st Aug 2021 12:19pm |
