Home > In Car Electronics (L322) > Retrofit homelink?
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Retrofit homelink?
So I've just moved house, and being at the end of a farm track, we have 2 five bar gates, both electrically operated with remote control and an electric garage door.
Not bothered about the garage door as my Lotus lives in there, but would be good to not have to fumble for the remote when coming down the track to open the gates.
Question is, can I retrofit homelink? I have a 2004 Vogue with the autodim mirror, I see a number of homelink rear view mirrors on ebay from the US - would these work in the UK? Is it a plug n play, or is there more wiring or control units needed? 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #512996 24th Apr 2019 10:15am
why not stick the remote with double sided tape to the sunglass holder...
Post #512999 24th Apr 2019 10:33am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
https://www.fullfatrr.com/forum/topic13168.html
Differing countries operate different frequencies -- there's a PDF freely available to download from TOPIX if you google it Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #513000 24th Apr 2019 10:39am
andygts
If your gate has a rolling code fob/receiver then homelink will not work. Tried, googled and failed.
I've got homelink in my FF but cannot use it on my gates or garage as they are rolling code and the aftermarket system I've fitted to get the house alarm, gate and garage all on one fob is also rolling code.
If you are adament that you want it then you can install an aftermarket fixed code receiver or if your setup allows set it to fixed code but compromise the security of the system.
The easier option if you really can't stand having an extra fob in the armrest is to hack into the wiring from the mirror buttons and connect them to the buttons on the fob. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #513001 24th Apr 2019 10:51am
I had Homelink on a couple of cars & could never get it working with rolling code garage doors - gave up & just used the fob.
Post #513002 24th Apr 2019 11:13am
SidewaysMatt
Laughing I guess that is pretty close to the OE solution! 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #513005 24th Apr 2019 11:46am
SidewaysMatt
Found it, thanks Thumbs Up 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #513006 24th Apr 2019 11:46am
SidewaysMatt
No clue if the gates or garage door are rolling code.
May just take a punt on this out of curiosity:
https://www.ebay.co.uk/itm/OEM-Range-Rover...1438.l2649 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #513008 24th Apr 2019 11:49am
andygts
Cheap enough to butcher but it won't work as intended in this country due to the operating frequency. Current
Previous
Post #513016 24th Apr 2019 12:31pm
