Home > Maintenance & Mods (L322) > Do these prices look ok?
Bingo_123
Recently bought a 10 plate 3.6TDV8, got the service and brakes done at local indy, all well so far.
but the RR came back with a list of things to be done soon.
Current Mileage is 101k.
1. N/S rear/front brake pipe corroded, £424.80 inc VAT.
2. N/S/F Driveshaft outer gaitor split out, lost grease. £384.58 inc VAT.
3. Gearbox Oil quite dirty, recommend to renew Auto box Oil and filter pan, £369.72 inc VAT.
4. Both rear shock absorbers are leaking excessively. £875.26 inc VAT.
I could feel the sluggishness in gearbox specially from a standstill, so was still deciding between a Gearbox Flush or just oil change. its defintely something i want to get done soon,
But others are a surprise , so please advise on the priority too, as to in which order i should get these done.
And if there is any cheaper alternative for these, i cant do it myself.
Thanks
Post #512396 17th Apr 2019 5:01pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi do you have a 6 or 8-speed gearbox if it`s the 8 then the price is ok, brake pipes mean that they will replace all of the brake fluid so not too bad, not sure about the gator but it`s a dismantling of the hub and everything attached to it so depends on labour gator is the cheap bit. Shocks? no that should be airbags which would make the car keep dropping down?
Post #512408 17th Apr 2019 6:18pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Brake pipes i would leave to the expert. Flaring tools etc are needed. It does sound a bit pricey though.
The gaitor can definately be done cheaper. You can buy them that wrap around the shaft and fasten up like a zip lock bag. 30 min job.
The gear box is reasonable if its a flush, not just a change. You will only get half the oil out unless its flushed. A member on here can flush it for you.
Both rear shocks is expensive. I assume he means the damper and not the bags. Not that hard to fit but a few different types fit your car.
They range from £80 - 250 each.
Why dont you send Dan at Duckworths a message and get parts prices. Then you can make a better judgement of cost.
Edit I can't seem to find tne split repair gaiter to fit a fatty. Maybe it has toge done the hard way Rolling Eyes 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #512414 17th Apr 2019 6:48pm
Bingo_123
Cheers guys, it did look a bit pricy to me.
Specially for the gaiter and brake pipe.
Mine is a 6 speed one.
Still undecided as to whether to go for gearbox oil change or flush.
Which member can do the flush ? Can you name please.
Regarding the dampers, I think the facelifted 3.6 ones are fitted with adaptive dynamics ones, that's why pricy.
Thanks
Post #512416 17th Apr 2019 6:58pm
Grofus
Cant remember who does the flush on here. Maybe do a search. I think he is in the midlands somewhere. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #512418 17th Apr 2019 7:07pm
Gsxr1250dave
There taking the Censored
Post #512430 17th Apr 2019 8:26pm
Tinman
Check these price`s from Island 4x4 https://www.island-4x4.co.uk/suspension-pa...mp;sort=3a
Post #512431 17th Apr 2019 8:35pm
Bingo_123
Looks like I need another quote/ vehicle checkup from another Indy.
Let me know if someone is recommended around d Essex and south east London.
Thanks
Post #512436 17th Apr 2019 8:58pm
Tinman
RST Landrovers Ltd, 1-3 Kingsland Road, West Mersea, Essex, CO5 8RB or two in Kent
Post #512443 17th Apr 2019 9:24pm
rjff
Bingo
I think the member who does flushes on the 'box is Bodsy. A search here and the web should find him. Guys on here rate him. Cheers
Richard
Gap IIDBT
Post #512445 17th Apr 2019 9:40pm
Chances are the front pipes are corroded, but original steel replacements are cheap as chips but not super easy to change. There is nothing that can't be fixed with a hammer😜😜
Post #512446 17th Apr 2019 9:40pm
Bingo_123
thanks guys, will be getting in touch with couple of other LR specialists to get the Driveshaft boot and Brake pipes done.
And will get the gearbox oil and dampers after this .
thanks
Post #512513 18th Apr 2019 12:47pm
