Home > Technical (L322) > Misfire problem |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
I had a never ending chase for misfires, plugs, coil packs etc....
15th Apr 2019 10:43am |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Cheers Gavin not sure if icarsoft will do that will check later .Took num 3 plug out looked at it it looks fine changed ignition coil and she has ran 5 miles perfectly crazy stuff |
15th Apr 2019 10:56am |
Should add my rocker cover gasket is needing done got a bit of oil down plughole but I have dried it all out and it is still doing it |
15th Apr 2019 11:00am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1527 |
As it's an M62, the oil must be coming from one of the rubber washers under the valve cover bolts which are inside the area surrounded by the gasket. Ron B. VK2OTC
15th Apr 2019 12:14pm |
Yes thanks or the gasket itself will get round to fixing it shortly |
15th Apr 2019 2:47pm |
Ok so missfire still there intermittent what to do anyone ? |
15th Apr 2019 6:30pm |
Changing the gasket won't make any difference to oil getting onto the plugs. I've been driving around for a week or so with the plastic covers removed and the plugs/coils fully exposed. No oil has accumulated in the plug chambers. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
15th Apr 2019 11:54pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
When you replaced coil packs did you replace the whole thing including the tubes or just the upper coil pack?
16th Apr 2019 12:44am |
Hi holiday just changed coli packs whole thing with rubbers not new ones though but working ones once changed and faults cleared she runs for a few miles no prob then starts misfiring again .Can I change rubber grommet without cover removal? |
16th Apr 2019 10:29am |
Oh and battery and alternator are good |
16th Apr 2019 10:30am |
Another update.changed a couple of spark plugs and coils on cylinder 2 and 3 cleared fault and she ran a dream gave her a good push uphills with no sign of miss parked her up for 3 hours went to shop and the misfire is back with a vengeance EML flashing etc .What can it be people.if it was valves it would do it all the time surely.engine not making any rattles or undue noise pretty quiet.it seems that she don't like being driven cold .Any ideas going slowly mad . |
16th Apr 2019 11:59pm |
Can you check faults again with your diagnostics, did you clear the previous faults ?
17th Apr 2019 6:59am |
Hi yes cleared all faults injectors box not disturbed going to have another go at it clean the maff clear faults check wiring etc don't understand why she will run ok until I switch her off and she cools down and restarts if I let her tick over on cold start for a while she seems to be better |
17th Apr 2019 12:21pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Crankshaft sensor (intermittent)?
17th Apr 2019 12:35pm |
