Home > Technical (L322) > Misfire problem
Page 1 of 3 123>
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Misfire problem
Hi guys it never ends here goes had a miss fire problem off and on plugged in icarsoft and it reads Avam shaft position timing over advanced or system performance bank 1 last occurrence minimum signal signal low. Persistent misfires drive cycle c . Cause last occurrence maximum signal. Cylinder 2 misfire cylinder 3 missfire .Have changed. Plugs and coils on both and it seems to run fine for a while until you push her and it starts misfiring again.any help would be realy appreciated
Post #512120 15th Apr 2019 10:17am
gavinn
I had a never ending chase for misfires, plugs, coil packs etc....
Turned out in the end it was valve seat regression , if you can look at the inlet vacuum values to see if they are in range ?
Post #512123 15th Apr 2019 10:43am
rik
Cheers Gavin not sure if icarsoft will do that will check later .Took num 3 plug out looked at it it looks fine changed ignition coil and she has ran 5 miles perfectly crazy stuff
Post #512125 15th Apr 2019 10:56am
rik
Should add my rocker cover gasket is needing done got a bit of oil down plughole but I have dried it all out and it is still doing it
Post #512127 15th Apr 2019 11:00am
p38arover
Australia
As it's an M62, the oil must be coming from one of the rubber washers under the valve cover bolts which are inside the area surrounded by the gasket. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #512143 15th Apr 2019 12:14pm
rik
Yes thanks or the gasket itself will get round to fixing it shortly
Post #512161 15th Apr 2019 2:47pm
rik
Ok so missfire still there intermittent what to do anyone ?
Post #512174 15th Apr 2019 6:30pm
p38arover
Australia
Changing the gasket won't make any difference to oil getting onto the plugs. I've been driving around for a week or so with the plastic covers removed and the plugs/coils fully exposed. No oil has accumulated in the plug chambers. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #512199 15th Apr 2019 11:54pm
holidaychicken
When you replaced coil packs did you replace the whole thing including the tubes or just the upper coil pack?
CATS. Blocking can give strange engine faults
Battery and alternator need to be tip top too
Post #512202 16th Apr 2019 12:44am
rik
Hi holiday just changed coli packs whole thing with rubbers not new ones though but working ones once changed and faults cleared she runs for a few miles no prob then starts misfiring again .Can I change rubber grommet without cover removal?
Post #512240 16th Apr 2019 10:29am
rik
Oh and battery and alternator are good
Post #512241 16th Apr 2019 10:30am
rik
Another update.changed a couple of spark plugs and coils on cylinder 2 and 3 cleared fault and she ran a dream gave her a good push uphills with no sign of miss parked her up for 3 hours went to shop and the misfire is back with a vengeance EML flashing etc .What can it be people.if it was valves it would do it all the time surely.engine not making any rattles or undue noise pretty quiet.it seems that she don't like being driven cold .Any ideas going slowly mad .
Post #512315 16th Apr 2019 11:59pm
holidaychicken
Can you check faults again with your diagnostics, did you clear the previous faults ?
Injectors or injector wiring, have you had the injector loom box off for any reason?
Post #512323 17th Apr 2019 6:59am
rik
Hi yes cleared all faults injectors box not disturbed going to have another go at it clean the maff clear faults check wiring etc don't understand why she will run ok until I switch her off and she cools down and restarts if I let her tick over on cold start for a while she seems to be better
Post #512368 17th Apr 2019 12:21pm
Crankshaft sensor (intermittent)?
or
Fuel pump/s... .
Post #512369 17th Apr 2019 12:35pm
Page 1 of 3 123>
