I have had my L405 for nearly 6 months now. Yesterday, when I parked on some slightly uneven ground - and I mean slightly uneven, when I opened the driver’s door, there was quite a loud “cracking” noise. When I got outside to investigate and moved the door backwards and forwards, I noticed that the leading edge of the drivers door was catching on the rear edge of the front wing, to the extent that it was chipping the paint away on both. It was having to force itself behind the front wing at the leading edge. This had never happened before, and back on completely level ground did not repeat itself. Surely the chassis is not so flexible that a slightly uneven parking location should cause this, particularly on a car designed to be used on uneven surfaces!!!!
I am wondering if anybody has experienced anything similar with their L405 or even L322 or has an explanation. Thank you.
