Home > Maintenance & Mods (L322) > 2007 SC Brembo seal kit |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
Can anyone confirm if this is the correct kit for the above car.
11th Apr 2019 7:59pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
You should probably replace the pistons while replacing the seals. The piston coating let's go and allows the aluminium to corrode. Ruins the seals and seizes the pistons. The ones from Zeckhousen Racing are not coated and should last longer. Stoptech 46mm pistons. 2007 L322 3.6 TDV8 Stornoway |
12th Apr 2019 6:14pm |
Cheers. Just found them there, link for anyone searching for this in future
12th Apr 2019 7:28pm |
https://www.rangerovers.net/forum/6-range-...ics/232090 2007 L322 3.6 TDV8 Stornoway |
13th Apr 2019 9:39am |
I’ve also found a company called Frentech in Burnley who offer a full rebuild kit for £89. 8 pistons and all boots and seals. Anyone used them?
14th Apr 2019 10:01am |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
These are the pistons I used - Budweg pistons which I was advised are very high quality.
14th Apr 2019 8:58pm |
