Home > Maintenance & Mods (L322) > Coolant Leak
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Coolant Leak
My 4.2 s/c gave a low coolant message the other day and when I looked the overflow tank was almost empty. Booked it into my local garage as I didn't want to drive 30 miles to my LR Indy with a coolant leak.
Local garage have diagnosed a pin hole in the pipe that goes from the thermostat housing to where they can't see. It goes under the supercharger.
They are suggesting, to fix will entail taking out the supercharger so a fairly long job. They freely admit they are not experts in the L322 so can anyone on here suggest firstly, what pipe this is and secondly, is there a work round to make the job easier.
Sorry I can't give more info. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #511673 11th Apr 2019 10:00am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I've done this on a 2006, the pipe isn't easy and it's definitely at least an input plenum off job. My T-stat failed and left me with the pin hole The hose goes down the valley to the back of the engine, I was able to get access after I removed a load of stuff and fortunately the pin hole was right at the join.
I had enough play in the hose to cut it and get the front re-connected, this is a bodge of course and you have to be careful not to put the hose under too much tension. Fact is I didn't have a spare car and only had 1 day leave left from work so I had to get mobile again quickly. Formerly happymadison1978
Post #511681 11th Apr 2019 11:25am
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Are there any options for silicone hoses on a 4.2? If it’s auch a pain to do it could be worth replacing with items that won’t perish.
Post #511685 11th Apr 2019 12:07pm
MrSkill
Had the exact same on my 4.2SC and the Super Charger had to come off to replace the hose, probably not what you wanted to hear !
Post #511687 11th Apr 2019 12:09pm
V8Noise
Thanks chaps.
Thankfully it won't be me losing knuckle skin as a trusted mechanic will be doing it over the next couple of months whilst I'm away.
Sounds like it's a fairly common problem. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #511757 12th Apr 2019 3:27am
V8Noise
All sorted by my indy and pipe replaced. Also found the PCV was gummed up so a new one went on whilst they were in there.
Back to normal now. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #519125 20th Jun 2019 3:58pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I’ve got the exact same problem. Would you mind me asking how much it cost to have it fixed? 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #519267 21st Jun 2019 10:28pm
V8Noise
Mulcher,
You'll be not pleased to hear it's a bit of a job so you won't get much change out of a grand, and that's at indy rates, not stealers. The pipe itself is nearly £300. They also found some other issues when they got in there to do with the PCV (on back order from LR) and throttle body gaskets. I believe the parts bill was over £350.
You'll obviously save a lot if you do it yourself but looking at the pictures of all the bits that came off, it looks a bit of a mission.
Not cheap running these old buses properly. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #519272 22nd Jun 2019 1:45am
Mulcher
Gulp, thanks V8Noise, looks like I’ll have to raid the kids piggy bank. 2006MY 4.2 SC
Post #519286 22nd Jun 2019 7:38am
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
A bit late maybe, but for the record:
I had to replace this hose also. Yes, it is below the intake and the Workshop manual procedure is to remove the supercharger and intake.
This is what I did:
Used vacuum cleaner to suck a rope though the old hose from the back of the motor.
Used vacuum cleaner to suck same rope through new hose at the back of the engine.
Tied something to the end of the rope so it won't get pulled through the hose.
Smeared vaseline on the visible part of the old hose and new hose.
Pulled the rope and the old hose from the front of the engine, the new hose pushes the old one out.
I first tried to use a standard straight hose because of the cost of the original one, but there is one or more sharp bends that made the hose collapse after a few heat cycles so just get the original one. Be generous with the vaseline, I suspect there are some sharp edges under the intake and it take some force to pull the hoses through. 2006 Supercharged
Post #530860 14th Oct 2019 4:50pm
crosby99
United States 2006 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Hello Ian928,
I know this is an old thread but just ran into what appears to be the same issue so thought I would reach out. Could you share the part number for the hose you replaced?
I would like to try your ingenious approach Smile
Thanks for your assistance!
Post #680078 11th Dec 2023 9:31pm
Ian928
Hello, I did a search, the part number I ordered was LR006147, be aware that this is a whole set with hoses and pipes and unneccesary expensive for the one hose you need. Maybe it is possible to get the single hose now? In 2015 only the kit was available.
I also read up a old post in a Norwegian Land Rover forum where I stated that I did not remove the fan and shroud but that I sort of regretted that I did not remove those items so consider what you want to do. I removed the thermostat housing and ordered new bolts and O-rings. I pulled the hose from the back of the engine though to the front, about 10cm/4” further forward than it should be, then fitted the hose to the thermostat housing and then pulled the hose back when fitting the thermostat housing. 2006 Supercharged
Post #680079 11th Dec 2023 9:50pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I looked at doing this (preventative rather than an urgent job) but what concerns me is that the kit hose has 2 hoses that go under the supercharger from back to front and couldn’t work out how the rope method would work with 2 hoses.
Please update when/if you do this, if possible with pics 👍
Post #680104 12th Dec 2023 8:14am
Ian928
I only changed the one hose. The other one I think you need to remove intake to change.
Edit: Found a video that show the process of removing the supercharger and changing both the hoses:
 2006 Supercharged
Post #680123 12th Dec 2023 11:21am
crosby99
Thanks Ian928! It looks like the hoses are still just available as a set but there are decent prices for the set on eBay.
I think I'll try your method first and then refer to that video if that doesn't work out.
Thanks again Smile
Post #680538 17th Dec 2023 3:14pm
