Home > Maintenance & Mods (L322) > L322 Roof Lining
MadL322
United Kingdom 2002 Range Rover HSE 4.4 V8 Cairns Blue
L322 Roof Lining
About to fit a shark fin dab aerial to the roof. Wondering if anyone has taken down the roof lining as will I need to drop the whole thing to drill the roof, or just drop the back end of the roof lining? Also, is it possible to feed cable through the roof on a rod rather than messing about with taking the pillars apart?
Post #511393 8th Apr 2019 10:14pm
You can't drop the roof without creasing it/damaging it, without taking the pillar covers off anyway...
Hope that helps Thumbs Up
Post #511398 8th Apr 2019 11:35pm
MadL322
so probably best to get a "pro" to remove and install aerial then, if they damage it, they can replace it. If so, might opt for an "evoque" dab roof aerial
Post #511400 8th Apr 2019 11:46pm
Fix aerial to tailgate spoiler then route cable into the car from the tailgate ?
Might look a bit odd, but less invasive.
Also powerfuluk do a video about changing the OEM aerial by just dropping the rear section of the headlining (a bit). Might give enough room to drill through (use a stop/guide on the drill) .
Post #511416 9th Apr 2019 7:44am
If you are positioning the aerial near the back end of the car it is easy enough to pull off the upper tailgate rubber seal and slide a piece of plywood/MDT board in between the roof and the headlining to protect the roof lining while you drill the roof.
If you fit the cable to the aerial first and feed it into the space above the headlining it's easy to fish for the cable with a rod with a nail in the end of it.
Once you have the cable at the back run it to the front around the edge of the headlining by unpicking the headlining as you go and pushing the cable behind it. Thumbs Up
Post #511425 9th Apr 2019 9:38am
