Home > Maintenance & Mods (L322) > L322 Roof Lining |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
You can't drop the roof without creasing it/damaging it, without taking the pillar covers off anyway...
8th Apr 2019 11:35pm |
MadL322 Member Since: 09 Oct 2018 Location: Yeovil Posts: 108 |
so probably best to get a "pro" to remove and install aerial then, if they damage it, they can replace it. If so, might opt for an "evoque" dab roof aerial |
8th Apr 2019 11:46pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Fix aerial to tailgate spoiler then route cable into the car from the tailgate ?
9th Apr 2019 7:44am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
If you are positioning the aerial near the back end of the car it is easy enough to pull off the upper tailgate rubber seal and slide a piece of plywood/MDT board in between the roof and the headlining to protect the roof lining while you drill the roof.
9th Apr 2019 9:38am |
