Home > Technical (L405) > Rocker panel removal
funnyguy1
United States
Just noticed that the right front door rocker panel wasn’t installed
quite right and need to remove and reinstall. Does it
Just pop off??[/i]
Post #511155 6th Apr 2019 8:17pm
I presume you mean the plastic panel on the lower wing (or fender)? Take a look at the video below sir Thumbs Up
Post #511172 6th Apr 2019 10:20pm
funnyguy1
United States
Hi Craig and thanks. It is the very bottom part of the rocker the one at 7:42 where he says don't pull this. It is not fitted correctly. The 1st 2 pics are the right side and the 3rd is the left side which is properly fitted. It needs to come off and then slid back up to hold it in. Mike
Post #511181 7th Apr 2019 2:38am
funnyguy1
United States
It is the very bottom piece not the 2 plastic trim pieces above (he broke one in the video) . Mike
\Thanks again for your help!!!!
Post #511182 7th Apr 2019 2:47am
funnyguy1
United States
Hi Craig,
This is the back of the exterior lower door trim panel I am dealing with. I am familiar with all the rear buttons except the 2 larger ones at the top of the top panel. Any idea how they release?
Mike
Post #511405 9th Apr 2019 1:48am
funnyguy1
United States
The 3 top larger pins are guidance pins. It has to be removed very slowly starting at the bottom and then working upwards using a trim removal tool popping the small lower buttons 1st. The guys at Powerful UK could have used a little more information before they destroyed that piece. It was not necessary. Thanks for the video though, it pointed me in the right direction. This is a great website!
Post #511528 10th Apr 2019 3:54am
