![]() | Home > Technical (L405) > Rocker panel removal |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
I presume you mean the plastic panel on the lower wing (or fender)? Take a look at the video below sir |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 390 ![]() ![]() |
Hi Craig and thanks. It is the very bottom part of the rocker the one at 7:42 where he says don't pull this. It is not fitted correctly. The 1st 2 pics are the right side and the 3rd is the left side which is properly fitted. It needs to come off and then slid back up to hold it in. Mike
It is the very bottom piece not the 2 plastic trim pieces above (he broke one in the video) . Mike
Hi Craig,
The 3 top larger pins are guidance pins. It has to be removed very slowly starting at the bottom and then working upwards using a trim removal tool popping the small lower buttons 1st. The guys at Powerful UK could have used a little more information before they destroyed that piece. It was not necessary. Thanks for the video though, it pointed me in the right direction. This is a great website! |
