Home > Maintenance & Mods (L322) > L322 CV gaiter replacement
rwilson
United Kingdom 2009 Range Rover Vogue TDV8 Zermatt Silver
Hi, I need to replace the OSF brake end front driveshaft gaiter and want to know how to do it.
I have successfully managed to change the pig of a lower ball joint today but during all the bashing I knicked the gaiter.
To replace the gaiter do I just need to split the 3 tapered joints, (lower arm, upper arm, and track rod), snip the two metal clamps and then pull the strut towards me hoping the half shaft will come out of the cv joint? I may need to remove the caliper as well but not sure. What I'm hoping is that I don't need to remove the front hub etc.
any advice most welcomingly received.
regards Richard
Post #511153 6th Apr 2019 6:32pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Simplest way is to undo big Knut holding driveshaft on hub undo top bush bolt to allow hub to swivel knock driveshaft through hub .You can buy neoprene gaiters that slip over cv joint with the aid of a cone and lots of grease a bit fiddly but saves a lot of time .Messy job but has to be done .Hope this helps
Post #511156 6th Apr 2019 7:34pm
rwilson
Hi, thanks for that. Is the hub/driveshaft nut a b**** to get off or manageable, ie does it need a windy gun or will a long breaker bar do the trick?
Post #511162 6th Apr 2019 7:53pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
following, as i have the same one to change....
Post #511163 6th Apr 2019 8:15pm
rik
I used a long breaker bar and a scaffolding pole with all my weight on it best done with car still on the ground getting the shaft out can aso be a bit of a chore but perseverance will overcome it .R
Post #511166 6th Apr 2019 8:33pm
mrblonde
Forgot to say, my local (non LR or indy) garage quoted £150+vat to do it
Post #511178 6th Apr 2019 10:56pm
Worth reading in relation to this:
https://www.fullfatrr.com/forum/topic47969.html
https://www.fullfatrr.com/forum/topic41095.html
When I do halfshafts, I usually remove the wheel centre then use the weight of the car and "Park" / Handbrake to provide the resistance for releasing the nut. .
Post #511180 6th Apr 2019 11:23pm
RJDS
Based on what a Bastard mine was to do........ Pay the £150 Laughing 2010 TDV8 3.6 Galway Green
Post #511204 7th Apr 2019 9:56am
rik
Yeh I agree pay the £150 it's a swine and you could get it wrong and end up costing more
Post #511236 7th Apr 2019 3:48pm
rwilson
ok, thanks for the advice. I'm going to tackle this job next weekend, I'll let you know how I get on!!!
Post #511956 13th Apr 2019 5:11pm
rwilson
Success - but not how I'd planned.
Some background: the car is in France where I have a good selection of tools but not anything man enough to remove the hub nut without risk of damage (new torque multiplier in UK).
So I set about removing the upright with a view of taking out the driveshaft and upright in one go (minus disc and caliper). All was going well until one of the bolts attached to the strut was seized solid, and it was properly solid. Umm, so after much annoyance I undid the strut and took it and the driveshaft out in one.
Managed to split the driveshaft from the disc end cv joint after quite a few hits (had thought this was going to come off much easier), new gaiter fitted, re-packed with moly grease and hey presto. After some man-handling I got everything put back together.
So car all tested, no issues, and the car is ready to drive back to the UK from the Alps on Monday. There was a point yesterday I thought that our new Hilux was coming back instead but dead chuffed its all resolved.
Now off to going skiing in 15+ dregee temps!
Post #512639 20th Apr 2019 6:51am
