Home > Maintenance & Mods (L322) > Windscreen draining pipes |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6406 |
No pipe that I am aware of.
4th Apr 2019 7:17pm |
Woddy4090 Member Since: 14 Mar 2019 Location: Cardiff Posts: 9 |
Thanks for your reply, it’s just strange that my battery drain has stopped since I silicone the hole , water mus of been making its way over electrics 👍 |
4th Apr 2019 7:34pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
There's a post earlier about water getting onto the battery and edward19 found that the scuttle, in which there are the drain holes to which the outer pipes are fitted, was warped. A touch of silicone on the scuttle when removed and refitted solved the problem. You may have solved this on yours.
4th Apr 2019 8:25pm |
Thanks for the link , that was a interesting read , the hole I have blocked up is a actual drain hole ( the centre one ) , I can’t believe RR has put pipes on the 2 outer drain outlets and not on the centre one ! Or have they and mine has been taken off or left off when the put a new battery on , |
4th Apr 2019 8:45pm |
I was going to have to looksee for this centre hole, but in the morning, however, being a conscientious FF owner and nosy have been out just now. (daft b r)
4th Apr 2019 8:59pm |
This is the centre windscreen wiper arm connecter , you can’t see the hole because I’ve covered It with silicone, th hole is dep in the crevis |
4th Apr 2019 9:14pm |
4th Apr 2019 9:16pm |
Thanks woddy.
4th Apr 2019 9:30pm |
Brilliant thanks , you can get your hand under the hole from back of engine, will be interesting to see if you have a pipe on yours , look forward to your reply 👍👍 |
4th Apr 2019 9:37pm |
Just had a look at mine and yep, there is a drain hole with a sort of socket under in the position you sealed. I had to take out the pollen filter assembly to see it. There is no pipe fitted to mine, thus I assume the contours of the filter assembly are designed so as to channel any water away to the siderear of the engine and thence to ground. Looks that way anyway.
5th Apr 2019 11:15am |
Thanks rjff for looking for me , I had tried everything to find the battery drain, reading everything on this forum , as it was draining with the slightest bit of rain , since I’ve blocked the hole it haven’t happened once , so it must of been making its way from there to one of the Ecu’s , with the amount of rainfall Wales has had in the last few days there’s been pair of animals looking for a big boat ! |
5th Apr 2019 11:33am |
You might want to check out your left rear cubby in the boot for water ingress - this is usually where it all goes wrong!
5th Apr 2019 1:27pm |
