Home > Technical (L405) > Towing Prep |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3858 |
Does anyone know what this is and does the L405 have it as standard. If I wanted to fit an aftermarket tow bar I understand that towing prep may be needed. Geoff |
3rd Apr 2019 6:31pm |
Yep, I still have my trusty (not rusty) L322 but purchase of L405 being considered and towbar essential. I would like a deployable but I can get a fixed one fitted pretty cheaply. Geoff |
3rd Apr 2019 7:46pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I hadn't thought about a deployable,
3rd Apr 2019 8:11pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1451 |
I seem to remember reading something, possibly on here, that because the L405 has an aluminium boot floor structure you have to have some sort of additional (and expensive) frame to be able to fit a towbar if it was not factory fitted.
3rd Apr 2019 9:43pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Yes Rob you are correct sir... The 405 needs a steel cage fitted around the boot floor/battery tray as the shell is Aluminium and would flex too much i guess... The Towbars i have seen all come with such a device and all the bolt holes are already printed into the chassis to fit said strengthening cage...
3rd Apr 2019 10:50pm |
fin Member Since: 20 Oct 2010 Location: South East London Posts: 51 |
Craig
4th Apr 2019 5:47pm |
And I will never know (unless someone on here knows)
4th Apr 2019 5:55pm |
107SW Member Since: 03 Jan 2016 Location: Yorkshire Posts: 43 |
Interesting. Like Geoff a 405 has caught my eye, but I too would prefer to have a towbar.
6th Apr 2019 9:31am |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
The handbook says that the max trailer weight off-road for the powered tow ball is limited to 1000kg. It also says that the max nose weight is 200kg instead of 250kg for trailers with overrun brakes. Everything else is the same for both. |
6th Apr 2019 9:54am |
Thank you. |
6th Apr 2019 12:03pm |
