Home > In Car Electronics (L322) > Radio problems
Cheapscaff
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
Radio problems
Hi all I have acquired a 2004 vogue and have a problem with the radio. On the radio head some times I can switch it on and off. And sometimes the if various buttons work and I get music. I have it all striped out and I can see no corrosion inside I have tried moving the main wiring in case a loose connection but no use. Do you think it is a radio head problem or something else. T.i.a
Post #509114 18th Mar 2019 7:39pm
Cheapscaff
Radio head
Anyone got any ideas on this is it the radio head or the receiver in the boot. I know it's a boring one.
T i a
Post #509311 20th Mar 2019 1:11pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
It's the stuff in the rear left had cubby box in the boot you need to be looking at!
I would suggest a nice long sunny day -- remove all units -- take lids off -- inspect carefully
Have contact cleaner and a toothbrush, soldering iron, various solid and multicore short lengths of cable, and some heat shrink available
It'll be fun, honest! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #509314 20th Mar 2019 1:57pm
Cheapscaff
Radio problems
Hi bushy thanks for taking the time to reply. I have today striped out the left hand side boxs and the sat nav is fried and the radio receiver (with 10 amp fuse in) has water damage I have cleaned it up with contact cleaner an tooth brush but it's still not working maybe fried also. It gets very warm in places after a couple of minutes. I think a second hand replacement is worth a try.
Post #509348 20th Mar 2019 4:55pm
Bushy30
It might be worth finding someone close to you with a working set and see if you can borrow units to plug in and see what happens Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #509398 21st Mar 2019 7:50am
Bushy30
or...............
https://www.fullfatrr.com/forum/topic50662.html Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #509438 21st Mar 2019 1:57pm
Cheapscaff
I have sent the control box off to be repaired. hopefully that will NOT be the start of a process of elimination. Maybe radio head next💰💰
Post #509503 21st Mar 2019 9:42pm
Cheapscaff
I got the unit back from the repair shop on the weekend and all is working fine now brilliant service and a very helpfull chap.
If you want his details pm me as I don't think I am allowed to post details on here. I have covered it all with plastic sheeting just in case I don't spot the leak.
Post #510571 1st Apr 2019 8:26pm
Cheapscaff
Check your pm jakebullet64
Post #510621 2nd Apr 2019 9:54am
control box ??? .
Post #510624 2nd Apr 2019 9:57am
Cheapscaff
BM54 radio module
Post #510686 2nd Apr 2019 4:35pm
Thumbs Up .
Post #510689 2nd Apr 2019 4:47pm
Cheapscaff
Nogin4x4 check your pms
Post #510987 5th Apr 2019 11:30am
