Home > Technical (L322) > Key fob and central locking
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
For some reason I can no longer lock/unlock my Rangie with the key fob.
The lock/unlock button under the hazard button, on the centre console, works ok.
Is this a key fob battery dead situation?
I’ve had no binging or bonging warning me of a low battery in the fob, though. 2007 3.6 TDV8
Post #510111 28th Mar 2019 2:07pm
first step is to change the keyfob battery.. Thumbs Up
Post #510116 28th Mar 2019 2:53pm
cheezels
Anyone have any tips with changing the battery before I wreck something?
Battery appears to be soldered in
 2007 3.6 TDV8
Post #510175 29th Mar 2019 12:13am
it shouldn't be..it slides out...
Post #510178 29th Mar 2019 6:42am
They charge through the ignition on an 07MY Stan... Thumbs Up
Post #510180 29th Mar 2019 7:00am
Doesn't RRUK do key refurbishments?
Might he be of assistance???
Post #510181 29th Mar 2019 7:06am
ur20v
A Trap
Battery definitely doesn’t ‘slide out’, you need to desolder the two pins from the battery on the circuit board. Get a repair kit or battery and you will see what to do. It’s not hard, just need a soldering iron with a small tip and a steady hand.
Post #510184 29th Mar 2019 7:36am
ur20v
A Trap
Check out nut job on YouTube, he did a video on repairing his key fob which included replacing the battery
Post #510185 29th Mar 2019 7:38am
so the batterys that charge via the ignition are soldered in, didnt know that....but, i assume that if the battery has gone past its recharge capacity then a new one is required..
Post #510187 29th Mar 2019 7:54am
cheezels
Thanks fellas much appreciated.
I’ll check out the YouTube video 2007 3.6 TDV8
Post #510211 29th Mar 2019 11:25am
