Home > Technical (L322) > New car 2008 TDV8 with diff problem?
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Hi, just picked up my new RR today and driving it home I noticed something that I didn't fully on the test drive.
Basically when on steering lock - parking, turning at a junction etc - it feels and sounds like the tyres scrubbing, as if the diffs were locked..?
Can anyone shed some light?
Car is on 119k, pretty comprehensive SH, seems looked after. Has x4 new tyres... Confused
Post #509925 26th Mar 2019 7:05pm
telly-addict
Okay, so I've plugged in my diagnostics and although there were a lot of errors, they were mostly spurious/historic or related to a failing battery (new battery just fitted by last owner).
I did notice that the configuration of the car listed; 'Centre Differential lock-up is fitted'
What is this?[/i]
EDIT
Found a couple of codes stored in the Transfer case control module that look rather suspicious;
P2789-00 Clutch adaptive learning at its limit
P186D-00 Clutch actuator is stuck
Looking like the Transfer case might be the problem...
Post #509954 26th Mar 2019 9:15pm
gizze
First thing to check, are the front and rear tyres matching?
If they are have they all got roughly the same tread? Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #510053 27th Mar 2019 11:11pm
telly-addict
Hi Gizze, yes they're nearly new vredsteins all changed at the same time.
Post #510059 28th Mar 2019 12:02am
GraemeS
With those transfer case faults I would be having the TC investigated.
Post #510062 28th Mar 2019 1:36am
