Home > Technical (L322) > Air suspension problem
jeffshaw
2008 3.6 V8. Front Left sensor signal voltage not in range - circuit voltage out of range. Have changed the sensor and it drops the rear drivers side airbag overnight. Have even changed the airbag. Any ideas what may be happening. Seems to be lowering and raising normally and drives fine but just get the suspension fault appearing every few miles.
Thanks in advance
ps had the front brake pipe replaced, would the garage have disturbed anything doing it??
Post #507887 7th Mar 2019 10:46pm
jeffshaw
Voltage is reading 5v as tested by autospark at the sensor. Still have the problem where the rear drivers side drops overnight despite ne airbag being fitted
Post #510039 27th Mar 2019 10:04pm
lazylabs
Have you checked the rear valve block?
Behind the wheel arch liner offside rear wheel.. Current Family:
2012 FFRR 4.4 TDV8 Westminster
2013 Jaguar XFs 3.0d Sportbrake
2008 FFRR 3.6 TDV8 VSE (Gone)
2008 Ford Mondeo mk4 2.2tdci (Gone)
2006 S Class 320 CDI (Gone)
1998 P38a 4.6 VSE Oxford Blue 98k (Gone)
Vx Vectra C Estate 1.9cdti 150 (with a few twists) (Gone)
Other LR's in Family (2019 4.4 TDV8 AB)
Post #510050 27th Mar 2019 11:48pm
Is sensor round the right way? .
Post #510057 28th Mar 2019 12:44am
