Home > Wheels & Tyres > General Grabber AT3 255 55 R20
Page 3 of 8 <12345678>
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
grey17 wrote:
Unnecessary quote removed
There is a big difference Martin but if your AT3s work well for muddy tracks and fields then thats fine but, having a Mud and Snow marking and 3PSMF does not make it a true Winter tyre. Winter tyres have many more sipes than an AT3 and the compound structure of the tyre is different.
My General Grabber Snow Grabber Plus have hundreds more sipes than an AT3 and the harder rubber of the AT3 make them fine to drive on during the summer months. Winter tyres are generally too soft for summer driving.
M+S & 3PSMF makes them more of an All Season but not a specialist Winter tyre.
What does make it a true winter tyre if m&s and snowflake doesn't, ie what other standards are there to compare to? Cheers
James
Post #509495 21st Mar 2019 8:44pm
grey17
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
Hi James.
It's all down to the construction of the tyre and the rubber/silica compound used to make the tyres.
True Winter tyres have a soft compound and thousands of sipes moulded into the tread blocks which help grip and spread out when on cold surfaces.
The tread design also helps hold onto snow as "snow on snow" is the best grip there is.
Summer tyres, All Season tyres and All Terrain tyres have a harder compound which gets hard and brittle as the temperature drops offering less and less grip.
There is a really great article here which I'll post for you to read as it gives all the standard parameters and tests used for a manufacturer to issue a M+S rating or a 3PMSF symbol.
Worryingly, it only requires a tyre to perform 25% better than a "comparison" tyre to achieve an M+S or 3PMSF rating!
As the old saying goes, its horses for courses and there is no one tyre which works well across all situations and seasons.
https://www.oponeo.co.uk/tyre-article/wint...e-m-s-mark
Cheers.
G
Post #509541 22nd Mar 2019 11:54am
JST
Thank you.
i was of the understanding that a snowflake symbol indicated it was of different silica content, where as it only needs to be 25% better grip is what your saying, nothing to do with tyre compound? Cheers
James
Post #509542 22nd Mar 2019 12:12pm
grey17
Hi James.
The Winter Tyre is THE specialist tyre for the colder months of the year and the soft compound makes it so. They also work extremely well on damp roads like we have here in the uk.
If you read through the link I posted, you'll come across the bit about the 25% being all that is required for a tyre to have the two, aforementioned markings.
These markings DO NOT qualify a tyre to be a Winter Tyre, merely that it is 25% better than the reference summer tyre that it was compared to.
Hope that makes sense!
G
Post #509543 22nd Mar 2019 12:19pm
Rob99
So, I guess the obvious question is "What markings indicate a proper winter tyre?" 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #509546 22nd Mar 2019 12:35pm
CS
The mountain snowflake symbol.
If you go on to ownerinfo.landrover you will see the winter tyres homologated by LR for 405s, there should be the same information for 322s somewhere. The list does include the Goodyear Duratrac which is not a 'mountain snowflake' tyre, and some which are not UK legal due to being studded, but there are at least three homologated mountain snowflake tyres, I think Pirelli Scorpion Winter, Michelin Latitude Alpin 2 and a Nokian. Continental Cross Contact Winter also in 21" and 22". Only Range Rovers since 1988
Post #509551 22nd Mar 2019 1:11pm
grey17
Hi Rob.
I guess you don't need specific markings for a proper Winter Tyre as it will say "Winter" or "Snow" or such like in massive letters on the sidewall. That's its sole purpose in life.
It will be supplied and marketed as a winter tyre and not omitting that the tread will have the characteristic sipes and tread pattern and be soft / slightly sticky to the touch.
The Germans and Austrians do great winter tyre tests every year and list all the best available for the forthcoming season and well worth looking at as they are very informative and educational Smile
Cheers.
G
Post #509552 22nd Mar 2019 1:18pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
General Grabber AT3's have the mountain snowflake symbol.
Best tyre Ive used . I cant recommened them enough 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #509570 22nd Mar 2019 5:25pm
Grofus
Post #509574 22nd Mar 2019 6:07pm
grey17
First one up here is a nice, concise video by Bridgestone about the major differences between winter, all season and summer tyres.
I'll track down a similar one I've seen for larger SUV's
A couple of others which also convey a good message.
Thanks
G
Post #509578 22nd Mar 2019 6:40pm
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Thanks for the pics, they look good. And going by the numerous recommendations, I think I know what my next set of tyres will be Cool 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #509587 22nd Mar 2019 9:08pm
AndrewM
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
DrRob wrote:
Andrew - got any piccies you can show us??
Picture of my 2010 MY L332 - With new GGAT3's 255/55/R20's - £159 each fitted
Post #509623 23rd Mar 2019 12:24pm
Baltic Blue
I am still hoping that someone will add a picture of a new AT 3 in the spare wheel well.
Cheers
Post #509625 23rd Mar 2019 12:27pm
AndrewM
Post #509636 23rd Mar 2019 1:53pm
Baltic Blue
Thumbs Up Bow down
Thank you Andrew, having seen your picture, to confirm it fits in, they will be my next choice of tyres.
Cheers
Post #509637 23rd Mar 2019 2:25pm
