![]() | Home > Technical (L322) > Major Failure to Proceed... Help! |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 74 ![]() ![]() ![]() |
Thanks again for all the input, guys.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Ignition switch is known to give similar problems. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Shaun (and anyone else with an interest)
Thanks for the prompt update, Tugger. I'm hoping to try and fix mine at the weekend so any new information will be very gratefully received. If your garage are right then I'm still baffled by all the seemingly unrelated warnings about the transmission, suspension , HDC ABS etc. that preceded the non-running issue. Annoyingly I had planned to do a full service and a transmission fluid change and have all the parts ready but I guess I ought to get it running first!
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Crankshaft Position Sensor Fault??? Would that stop the fuel pump running, I know it will stop the car starting. 2007 TDV8 VSE
Shaun,
Thanks, Both.
My issue was a sticky fuel regulator in the high pressure pump. Its regulates the return flow to the tank and open and shuts to maintain the correct pressure in the fuel rail. A heavy dose of injector cleaner and fuel system lube along with an Italian tune up for 20 miles sorted it.
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
first code is P2290 - Injector Control Pressure Too Low.
Why dont you open the bonnet and check that diesel is get pumped to the filter. Just pull the retaining clip on the feed pipe and pull off the pipe. Get someone to turn ignition on and off while you check the flow.
Thanks guys.
OK. So I checked diesel flow at the Schrader valve between the filter and the high pressure pump. Nothing. Checked the fuel pump fuse and relay, both in the fuse box under the bonnet. Both fine.
Glad you got yours sorted Shaun, and a no cost - bonus! Hope you enjoy many more miles of trouble free RR driving.
Glad you've got yours back, Tugger. Happy motoring. Have a great weekend.
