![]() | Home > Technical (L322) > Major Failure to Proceed... Help! |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 934 ![]() ![]() |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 74 ![]() ![]() ![]() |
This forum really is fantastic! Thanks for the replies.
Thanks, Tugger...those are exactly my symptoms (leaving out the earlier hesitant starting issue which I'm beginning to think may be unconnected).
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
why would a failing alternator prevent the car from starting?
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6415 ![]() ![]() |
"spinning the starter"
I must agree with fray an alternator wont stop it from starting and if its spinning over battery must have a charge |
THIS is why I'm confused!!!
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
As I sit here reading, I've remembered what may be a crucial point - the recovery man actually did get mine to start very briefly, it would only run for about 3 or 4 seconds and then die. It wouldn't even last long enough to drive itself onto the recovery truck. So I reckon battery and starter are OK - its just the minute the alternator is called up to spit out some juice, it fails.
Thanks, Tugger. That makes your symptoms even more identical to mine!
exactly. Shaun, is that what happens? key in position 3, the starter motor engages and turns the engine over rapidly like its trying to start but it just doesnt fire into life? |
Precisely 2012 TDV8 Westminster in the New Forest
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
I know if the diode pack of the alternator is J. Arthured it can prevent the car starting as not enough power gets to the coil packs. It can also drain a previously charged battery a lot faster.
Isn’t it a TDV8? |
You can disscconect the alternator on any motor it will still spin over and start if the battery is charged |
