![]() | Home > General (L405) > Land Rover Approved 165 point check. |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 ![]() ![]() |
The check sheet just gets ticked and filled with lies.
So Member Since: 25 Sep 2017 Location: UK Posts: 16 ![]() |
To be honest the dealership has been a bit tricky so far.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
Unless I am missing something the minimum disc thickness is not in that thread.
Is about allI can see - what the wear limit is is anyones guess...... |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 359 ![]() ![]() |
Depending on which variant you have, new discs are either 20 or 25mm thick and both have a 3mm wear limit
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Sizes/thickness's are stamped into your disc bells... Remaining thickness can then easily be measured |
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 85 ![]() ![]() ![]() |
I too thought that the disc lipping on my 27,000 mile L405 was excessive, however in talking to two (admittedly L-R) garages before I bought the car (from another L-R garage) they told me that there was plenty of 'meat' left on the disc, and that a new disc only starts 2mm thicker than the minimum thickness (stamped around the hub area of the disc) and that this wear-rate would equate to 50,000 miles which is normal.
