Home > Off Topic > WIFI DUEL ROUTER ADVICE
Page 2 of 3 <123>
Dogman
Gazellio wrote:
Off too PC World then........ Whistle
Report later Very Happy
It's nice to see there are still some constants in life Thumbs Up
Post #50853 19th Feb 2011 11:04am
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
No No dont do it dealing with assh**** who do not have a clue about Censored  Far to many gone...
Post #50865 19th Feb 2011 12:00pm
I only nneed the product they can go...... Censored
Post #50867 19th Feb 2011 12:04pm
diesel
United Kingdom 2010 Range Rover Vogue SE TDV8 Java Black
Get them to price match Amazon Shocked
Post #50869 19th Feb 2011 12:06pm
will try
Post #50872 19th Feb 2011 12:16pm
If you are going to add a second wireless router, make sure you set it up with a different subnet for dhcp, or turnoff dhcp and only allow specific IP addresses for specific devices. Things can get messy if you have two routers on the same subnet serving up the same range of IP addys. Security is important, so WPA2 at least, and for double strength control via MAC address too.
Some friends of mine had a similar problem with a "long" house and the wireless router being at one end on the ground floor. Using the Powerline concept they get good connections and speed from the upstairs rooms.
It does seem to help having the router/antenna up high, so upstairs may be better than downstairs.
I ran CAT5 cable all over my house (and around the outside of it) so that wireless is only an occasional activity (mostly smartphone). You might need to buy a couple of "switches" to allow for adding more than one wired device to a cable.
I still have a 16 port switch waiting to go in up in the loft!
Now if only I could get a decent mobile phone signal inside my house Big Cry .
Post #50885 19th Feb 2011 3:14pm
Gazellio wrote:
This one seems to do everthing without needing a second Router/Access Point:
DEVOLO dLAN 200 AV Powerline Adapter Wireless-N Starter Kit (£119.99) PC World
Got two sets of those Gaz in my setup along with two broadband packages one from sky broadband and the other from 02 broadband as i have the same problem with coverage ... Thumbs Up
Post #50901 19th Feb 2011 5:06pm
Ok I got the Netgear AV 200 and am about to set it up.....
Post #50906 19th Feb 2011 6:02pm
OK it took 5 minutes from out of the box to fully working in the previously dead zone of the house! Most impressed and the signal seems excellent.
Highly recommend (especially AT Amazon PRICE Very Happy )
Post #50909 19th Feb 2011 6:55pm
bogie
good news...they are pretty plug n play, certainly not cheap but often easier than running new cable everywhere ! cheers
bogie
Post #50923 19th Feb 2011 8:58pm
Only concern seems to be that the new access point is open and does not require password following set up as advised?
Post #50925 19th Feb 2011 9:11pm
Only two problems are:
1. Now that the Netgear Powerline Extender is working in the dead-spot I cannot get the tablet to connect to the original Belkin Wireless Router when upstairs. It just says "obtaining IP address " and then fail to connect?
2. When it connects to the new wireless access point "NETGEAR" it does so on an open basis without the need to login. This is how it set itself up following the instructions but I was expecting a bit of security and a password?
Clear your Sunday morning heads IT Guys I would appreciate any help you can offer? Very Happy
Post #50974 20th Feb 2011 9:26am
ukrangie
For the Belkin router, trying deleting the connection and re-adding it. Paul
Twitter - Facebook
Post #50976 20th Feb 2011 9:38am
On the Tablet Android 2.1 os I did this - you click "Forget this connection" but scan immediately finds it and adds it again you click connect then obtaining IP Address and failure. Worked fine before I added the new Extender connection.
Other computers/laptops still connect with the Belkin Router as before...
Post #50977 20th Feb 2011 9:42am
bogie
generally when using mulitple wireless access points to cover an area there are some simple rules to follow:
1. set them ALL up on the SAME SSID (network name) so call them all "myhouse" (whatever) ...dont leave it just on Netgear by default ...make it same as Belkin ...then client devices "roam" between whichever is more powerful
2. set them ALL up with SAME encryption type and password; usually this is WPA or WPA these days, 8 characters minimum ...again, this is so you only set clients up once, and they roam between access points
3. set the access points up on different channels, if upstairs is on 1 then downstairs is on 6 ...or on some fancy ones, leave it to "auto" and it will take care of itself
so you should only have to set clients up once, and thats it ...dont have it seperate otherwise you are continually having to input details, re-authenticate and get IP address every time you move around the house....which is not how its supposed to work ..... cheers
bogie
Post #50995 20th Feb 2011 12:03pm
Page 2 of 3 <123>
