Home > General > RA GE ROVER
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
RA GE ROVER
Afternoon all, after cleaning the range today, some thread from my coat caught the letter N on my bonnet, so its come off the car. Any tips or aadvice about getting it back on
Thanks in advance, Phil
Post #50888 19th Feb 2011 3:38pm
its quite easy to put a coat back on.... Very Happy
double sided tape or a bit of 'no nails' or similar.. Thumbs Up ... - .- -.
Post #50896 19th Feb 2011 4:59pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Rolling with laughter
You are on form today mate....
Phil - I suspect the only neat way is to get a new one with the glue already on it. Not sure what aftermarket glue would do the job as well. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #50897 19th Feb 2011 5:00pm
Reformed
I would say the correct way is to replace the whole badge but if it was mine, I would clean up where the letter was on the car and the adhesive behind the badge itself,, then apply some body adhesive tape of the same thickness to the back of the badge, then use a sharp knife to trim it before re applying it.
You will probably still have a very faint outline on the paint to line the badge back up.
Just take your time and don't rush. You can buy the body tape from most good motor factors, something like 3M body and trim. Reformed
Post #50910 19th Feb 2011 6:59pm
T24RES
I used number plate double sided from halfords when i pinged mine off. Clean out the old, place over the new then use a craft knife to trim using the lip as a guide. (if you turn it over you'll understand what i mean) Affix on the sun stained spot and job done. Ian
Post #50927 19th Feb 2011 9:39pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
If you buy the full set of letters they are mounted on a card that is preformed/cut to make positioning correct on the production line. IIRC forum sponsor DCC 4x4 sells the letter sets 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #50937 19th Feb 2011 10:19pm
ukrangie
I'd say leave it as it is. Might make a few people move out of the way Laughing Paul
Twitter - Facebook
Post #50971 20th Feb 2011 7:09am
liverpoolphil
Thanks for the input, I'll try some adhesive today and if that doesn't work, ill get some new.letters
Post #50973 20th Feb 2011 7:30am
Adhesive Shocked Shocked
Best with 3m vehicle tape .....
Post #50978 20th Feb 2011 10:22am
liverpoolphil
Got some vehicle adhesive pads, hopefully this will do the job
Post #50993 20th Feb 2011 11:28am
