Home > Maintenance & Mods (L322) > Fuel Additives... |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Jeez, Stan, and there's me thinking you didn't look a day over 69! Mike |
14th Mar 2019 8:09pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
time fly's Mike.... |
14th Mar 2019 8:23pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
SO HOW TO YOUR BELOVED FFRR ENGINE - Listen to these guys & follow what they say !!!!! One thing I take a great interest in is engines ! and one thing I would NEVER EVER DO - is put 2 Stoke into a modern diesel engine - YOU are asking for problems ( and by the way "Under Warranty go and tell the main dealer you put 2 Stoke Oil in your Tank - Then watch him smile ! (You have now become his and the Workshop Mangers best friend ) There are many arguments, mostly on motoring forums like its one about whether or not to add 2 stroke oil to diesel engines. Their main argument is that this will improve the lubricity of the fuel, particularly low sulphur fuels of around say: (50ppm/10ppm) diesel. We all know Sulphur occurs naturally in oil. But It is undesirable for various reasons - 1) main reason is that the sulphur from the FFRR exhaust pipe forms sulphuric acid in the atmosphere which results in acid rain. In the vehicle it pollutes the engine oil reducing its life. Using a low sulphur diesel reduces both the environmental pollution and the pollution of engine oil. In order to produce low sulphur diesel, the sulphur has to be removed and the process that removes the sulphur reduces the lubricity of the diesel. FACT: Diesel pumps and injectors rely on this to keep them lubricated. So Should YOU add 2 Stroke Oil to your diesel to improve its lubricity? In short, you shouldn't - NEVER in fact 2 Stroke Oil is designed for 2 stroke motorcycle engines, not 4 stroke vehicles. Vehicle manufacturers and ALL fuel refining companies all agree that running 2 Stroke Oil in fuel is likely to cause complications and there have been reports of engine failures due to 2 Stroke Oil sludging up valves and fouling injectors. Seeing the picture above - You guys have fun with your 2 Stoke in your fuels ! All fuel refineries have produced lower sulphur diesel, so too have they added lubrication substitutes to the new diesels to the point that lubrication is now even higher than that of high sulphur diesel. LR certainly don't recommend putting 2 Stroke Oil in your diesel engine ? Funny thing also - fuel companies don't recommend putting 2 Stroke Oil in your diesel ? Still cant understand why also The 2 Stroke Oil manufacturers don't recommend putting 2 Stroke Oil in your diesel - They know something you don't. therefore it is a simple deduction that there is NO REASON to add 2 Stroke Oil to your diesel! My only advice - IF YOU ARE BUYING A USED FFRR - WALK AWAY FROM ANYONE WHO HAS PUT 2 STOKE IN THEIR TANK. I hear them say .... Oh it sounds quieter ? Well just go and get it serviced with quality fuels and oils IF YOU CAN'T AFFORD TO BUY TOP QUALITY FUEL FOR YOUR RANGE ROVER - GO AND BUY A FORD FIESTA ! - How tight can you get ! |
14th Mar 2019 9:07pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Waste of money in my opinion..
14th Mar 2019 10:08pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I never tried two stoke oil, just additives that appeared to do nothing oh and of course gallons and gallons of fuel from my local Tesco - that also appeared to do nothing good or bad, in fact it still doesn't. I can afford to put any fuel in my RR but choose not to if I was bothered I would have bought a more economical diesel than a 5.0L Supercharged Petrol.
15th Mar 2019 7:34am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
15th Mar 2019 8:54am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Tesco get their fuel from the same supplier as Esso, if I remember correctly. So its decent quality.
15th Mar 2019 12:04pm |
they may collect the fuel from the same refinery but its on the tanker that the additives ,if any , are added.. |
15th Mar 2019 12:17pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Diesels are called oil burners for a reason, it’s distillate. Modern diesel is lower sulphur, because it’s cleaner.
16th Mar 2019 10:43am |
SilverParrot Member Since: 09 Aug 2018 Location: Herts Posts: 25 |
I run my 04 td6 on asda fuel. No problems.
16th Mar 2019 12:08pm |
Stan, You look to be one the verge of entering the interminable, illogical, unanswerable, pointless discussion on fuel additives - don't do it - I know its raining and we are bored but - don't do it Geoff |
16th Mar 2019 1:57pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
But you don't have DPF on your td6. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
16th Mar 2019 3:14pm |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
I run a company which uses numerous two stroke machines and I'm not so sure I'd mix two stroke oil with diesel. One of the most common problems we find with two strokes is a blocked exhaust through carbon build up and unburnt oil. This results in the engine not being able to 'breathe' in and out and as a result trying to exhaust through the carb. This particularly applies to mineral oil as well. Given the sensitive nature of DPF's etc. in modern cars I can't see it being a good thing. That said, I do put a dash of Castrol R two stroke in my four stroke lawnmower as the smell of burnt castor oil is great and makes cutting the grass a pleasure |
16th Mar 2019 3:17pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
','That said, I do put a dash of Castrol R two stroke in my four stroke lawnmower as the smell of burnt castor oil is great and makes cutting the grass a pleasure''
16th Mar 2019 3:32pm |
