Home > Maintenance & Mods (L322) > Fuel Additives...
Page 3 of 4 <1234>
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I’m overseas for a few weeks now but last weekend I decided to try adding 2 stroke to my fuel.
I bought 500ml of mineral 2 stroke oil from Wilco’s (£2.50) and then added it to the tank before filling it full at the local Shell garage.
Later that day I took Mrs Jim out, in what she refers to as “Your old banger” (she is not convinced by my decision to invest in a 14 year old car! lol) only for her to say that the engine sounded quieter since I had serviced it.
Now I could have imagined it but I too thought that the engine sounded smoother and it felt a little more responsive?
Jim
Post #508692 14th Mar 2019 2:31pm
mpirie
stan wrote:
i to have been using supermarket fuel from as early as the mid seventies.
Jeez, Stan, and there's me thinking you didn't look a day over 69! Whistle
Mike
Post #508752 14th Mar 2019 8:09pm
time fly's Mike....
Post #508755 14th Mar 2019 8:23pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Jri711 wrote:
So what’s the ratio of two stroke to diesel? & what’s the benefit / reason for its use ? I ask because I’ve never heard of this befor.
SO HOW TO Censored YOUR BELOVED FFRR ENGINE - Listen to these guys & follow what they say !!!!!
One thing I take a great interest in is engines !
and one thing I would NEVER EVER DO - is put 2 Stoke into a modern diesel engine - YOU are asking for problems ( and by the way "Under Warranty go and tell the main dealer you put 2 Stoke Oil in your Tank - Then watch him smile !
(You have now become his and the Workshop Mangers best friend )
There are many arguments, mostly on motoring forums like its one about whether or not to add 2 stroke oil to diesel engines. Their main argument is that this will improve the lubricity of the fuel, particularly low sulphur fuels of around say: (50ppm/10ppm) diesel.
We all know Sulphur occurs naturally in oil. But It is undesirable for various reasons -
1) main reason is that the sulphur from the FFRR exhaust pipe forms sulphuric acid in the atmosphere which results in acid rain. In the vehicle it pollutes the engine oil reducing its life. Using a low sulphur diesel reduces both the environmental pollution and the pollution of engine oil. In order to produce low sulphur diesel, the sulphur has to be removed and the process that removes the sulphur reduces the lubricity of the diesel.
FACT: Diesel pumps and injectors rely on this to keep them lubricated.
So Should YOU add 2 Stroke Oil to your diesel to improve its lubricity?
In short, you shouldn't - NEVER in fact
2 Stroke Oil is designed for 2 stroke motorcycle engines, not 4 stroke vehicles. Vehicle manufacturers and ALL fuel refining companies all agree that running 2 Stroke Oil in fuel is likely to cause complications and there have been reports of engine failures due to 2 Stroke Oil sludging up valves and fouling injectors.
Seeing the picture above - You guys have fun with your 2 Stoke in your fuels !
All fuel refineries have produced lower sulphur diesel, so too have they added lubrication substitutes to the new diesels to the point that lubrication is now even higher than that of high sulphur diesel.
LR certainly don't recommend putting 2 Stroke Oil in your diesel engine ?
Funny thing also - fuel companies don't recommend putting 2 Stroke Oil in your diesel ?
Still cant understand why also The 2 Stroke Oil manufacturers don't recommend putting 2 Stroke Oil in your diesel - They know something you don't.
therefore it is a simple deduction that there is NO REASON to add 2 Stroke Oil to your diesel!
My only advice - IF YOU ARE BUYING A USED FFRR - WALK AWAY FROM ANYONE WHO HAS PUT 2 STOKE IN THEIR TANK. I hear them say .... Oh it sounds quieter ?
Well just go and get it serviced with quality fuels and oils
IF YOU CAN'T AFFORD TO BUY TOP QUALITY FUEL FOR YOUR RANGE ROVER - GO AND BUY A FORD FIESTA ! - How tight can you get !
Post #508763 14th Mar 2019 9:07pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Waste of money in my opinion..
I have always used the VPower or Ultimate range which has additives included in the fuel. Never used supermarket fuel and never had any issues (including black smoke)
The overall difference works out £5-£8 more over a tank so not like its breaking the bank. Never compromise on the fuel, fuel filter, oil and oil filter aswell as the air filter. I always get genuine. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #508770 14th Mar 2019 10:08pm
supershuttle
I never tried two stoke oil, just additives that appeared to do nothing oh and of course gallons and gallons of fuel from my local Tesco - that also appeared to do nothing good or bad, in fact it still doesn't. I can afford to put any fuel in my RR but choose not to if I was bothered I would have bought a more economical diesel than a 5.0L Supercharged Petrol.
Maybe even a Ford Fiesta Whistle Geoff
Post #508784 15th Mar 2019 7:34am
Embarassed
Post #508790 15th Mar 2019 8:54am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Tesco get their fuel from the same supplier as Esso, if I remember correctly. So its decent quality.
Not sure about other supermatket chains.
Diesel is all about cetanes. The more it has, the better it burns. That is determined by when it vapourises during fractional distillation. Branded fuels are better quality and have additives to clean and lube the fuel system. You pay your money and make your chioce.
If I used lower quality fuel, I would use an additive. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #508812 15th Mar 2019 12:04pm
they may collect the fuel from the same refinery but its on the tanker that the additives ,if any , are added..
Post #508817 15th Mar 2019 12:17pm
rar110
Diesels are called oil burners for a reason, it’s distillate. Modern diesel is lower sulphur, because it’s cleaner.
I can’t see how adding 250mm of 2 stroke oil to 100lt of diesel would do anything too adverse. JLR are supposed to have motors that suit a range of conditions. ______________________________
Post #508894 16th Mar 2019 10:43am
SilverParrot
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
I run my 04 td6 on asda fuel. No problems.
MY 06 TD6 Jag with DPF gives me DPF warnings using asda fuel but not with Shell Ultimate.
Mileage on the both cars includes frequent long runs.
Post #508900 16th Mar 2019 12:08pm
supershuttle
Stan, You look to be one the verge of entering the interminable, illogical, unanswerable, pointless discussion on fuel additives - don't do it - I know its raining and we are bored but - don't do it Very Happy Geoff
Post #508910 16th Mar 2019 1:57pm
Weegie
But you don't have DPF on your td6. Wink John
GAP iiD BT
Post #508918 16th Mar 2019 3:14pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I run a company which uses numerous two stroke machines and I'm not so sure I'd mix two stroke oil with diesel. One of the most common problems we find with two strokes is a blocked exhaust through carbon build up and unburnt oil. This results in the engine not being able to 'breathe' in and out and as a result trying to exhaust through the carb. This particularly applies to mineral oil as well. Given the sensitive nature of DPF's etc. in modern cars I can't see it being a good thing. That said, I do put a dash of Castrol R two stroke in my four stroke lawnmower as the smell of burnt castor oil is great and makes cutting the grass a pleasure Very Happy
Post #508919 16th Mar 2019 3:17pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
','That said, I do put a dash of Castrol R two stroke in my four stroke lawnmower as the smell of burnt castor oil is great and makes cutting the grass a pleasure''
Love it !!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #508920 16th Mar 2019 3:32pm
Page 3 of 4 <1234>
