Home > In Car Electronics (L322) > IPhone X
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
IPhone X
iPhone X crackly on 2011 L322...driving me nuts.
Works better if I throw the phone in the back, so must be signal related, however it seems the phone is known to have Bluetooth issues.
No corrosion on Bluetooth module, up to date firmware. Slightly spoiling my experience, but wondered if others had had this experience, or if it is my phone/car specific?
Jon 2011 Stornaway Grey 5.0SC Autobiography
Post #502910 26th Jan 2019 10:33pm
Mr Tee
Had an x hooked up to my old one with nil issues mate. Can you try another?
Post #502929 27th Jan 2019 9:09am
GGDR
I get a bit of a crackle on my iPhone 7 (also 2011 VSE) but it seem to be when the phone is ringing and clears when the speaking starts.
More of a tiny annoyance. But be good to know what's causing it.
. Cheers, Greg
Post #502936 27th Jan 2019 11:06am
mine Does the same in the fatty, but strangely not in the Disco.
its a problem a few have had on here, but don't think there is a work around yet. My iPhone 7 didn't do it...
Do you have a tune 2 air on? I'm going to try disconnecting that and see if it improves. There is nothing that can't be fixed with a hammer😜😜
Post #502944 27th Jan 2019 11:43am
jonlewis
I do have a Bovee, but tried with and without it.
If I sit in the boot with the phone, it is clear as a bell, I suppose I could just put my phone in the boot, but it is a bit of a faff and obviously also means I can use it for Waze or similar
Going to try a couple of other phones over the next week and see what happens. Checked all the connections on the Module itself and it is clean as a whistle.
Post #502965 27th Jan 2019 3:40pm
tuki
Turkey 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I am having the same issue for a long time. When I leave it on the passenger seat it's a lil better but still annoying. Couldn't find a solution.
My iPhone is US Spec and the RR is Euro, maybe it's something to do with it. As you'd know us spec mainboards on phones are different due to GSM/CDMA bilateral functions. Just a thought. I bought a new iPhone XS and i'll give it a try with that.
Meanwhile Samsung phones works crystal clear.
Post #503146 28th Jan 2019 10:05pm
Nick Evans
My iphone X is terrible in mine.
It was fine in my D4 so am thinking of possibly fitting a D4 bluetooth module into my L322 to see if it rectifies the issue.
Post #503390 30th Jan 2019 9:41pm
jonlewis
I have an iPhone 6 and a Windows phone to try over the weekend and will report back. 2011 Stornaway Grey 5.0SC Autobiography
Post #503399 30th Jan 2019 11:19pm
Super7
Did you guys sort your phones? I've just blue toothed my XS on my 2010 SC and although it works it wont load my contacts, I an access the call records but not contacts/address book have you chaps any ideas/solutions?
Cheers
Post #508858 15th Mar 2019 5:55pm
