Home > Maintenance & Mods (L322) > Mercedes Sprinter Jack
supershuttle
I'm sure I must've posted this before, why bother with add on bits - just modify the standard jack,
 Geoff
Post #508360 11th Mar 2019 10:49pm
That’s not the top bit that my sprinter jack came with 👍🏻 Which was more of an under axle U/V shape There is nothing that can't be fixed with a hammer😜😜
Post #508625 13th Mar 2019 8:08pm
supershuttle
Ah, I filed the horns down and welded a bit of flat steel on top, the rubber is just a finishing touch. Geoff
Post #508631 13th Mar 2019 10:14pm
Cool.
Beyond my skill set😜 There is nothing that can't be fixed with a hammer😜😜
Post #508641 14th Mar 2019 12:13am
supershuttle
and mine - I got my brother in law to do most of it, only downside is I can no longer call him a "useless Censored ".
I did the filing Very Happy Geoff
Post #508649 14th Mar 2019 7:50am
At risk of hearing much teeth sucking....
I've found that the standard "horned" top fits inside the standard LR cup on the FF without modification (across the diagonal) so I just jack it up like that and all seems to be well. I can see that there will be significant pressure points with the horns in the corners of the cups, but that aside it all seems very secure - as far as a narrow 50 - 60 cm pillar holding up the corner of a very heavy car can ever be considered secure. What extra do you consider that these custom fit pads are doing for you?? Mike - MPx
Post #508687 14th Mar 2019 1:36pm
