Home > Technical (L322) > Switch beneath the steering column |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Hi Folks, Just joined the forum as I read it so much I thought I might as well get involved a bit more.
18th Apr 2009 10:41pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
If memory serves me it's to disable the cars electrics during delivery and is disabled during the dealers PDI. From then on it's main purpose is to confuse the curious 2008 MY Supercharged
19th Apr 2009 6:46am |
Mudplugger Member Since: 20 Feb 2009 Location: err... near Inglewhite, Lancs. Posts: 95 |
This had always had me curious too. So post PDI is it correct to say it has NO function?
19th Apr 2009 10:22am |
Are you mad? For all we know you might end time and stop the Universe!
19th Apr 2009 6:39pm |
Thanks for that folks. Funny thing to have in such an accessible place. Mind you, it did take me 15 months to spot it in the first place I suppose!! Why do I know I'll end up clicking it to the right at some stage, unintentionally of course.
20th Apr 2009 12:30am |
Thanks for the extra info. Any knowledge of these things much appreciated.
21st Apr 2009 7:25am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
Mine doesn't have this switch under the sterring column. (06MY) Discovery 4 HSE
21st Apr 2009 9:28am |
BBS SPY Member Since: 20 Apr 2009 Location: Limassol Posts: 101 |
I believe it was only the later more fully CAN bus vehicles that had it. Not sure if they still have the Pyro Isolater fitted, which can, by control from the Airbag ECU, explosively disconnect the positive battery Lead. |
21st Apr 2009 10:35am |
The poster's vehicle is the same age as mine though so that doesn't make sense. Discovery 4 HSE
21st Apr 2009 3:18pm |
Diesel L322's did not get converted to CAN BUS until the introduction of the TDV8, with the exception of the entire infotainment system which was fitted from 2005 on to all models and is is all linked together by the MOST fiber optic bus. Therefore a 2006 Petrol is mainly CAN and a 2006 Diesel mainly BMW.
21st Apr 2009 3:54pm |
Nice clarification!
21st Apr 2009 7:50pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 787 |
Can someone explain what is the use of the funny shaped hole near the lamp (the circled one)? It doesn't seem to have any visible purpose...
14th Mar 2010 2:29pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 771 |
RRVSE - I found this switch some time ago (took me just less than a year! ). The consensus is that it shouldn't actually do anything. If you press and hold it in either direction then the whole ignition system stays live. Interesting from a theft perspective I think......
15th Mar 2010 9:51am |
The buzzer/gong goes in there:
16th Mar 2010 11:25am |
