![]() | Home > Technical (L322) > Switch beneath the steering column |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Hi Folks, Just joined the forum as I read it so much I thought I might as well get involved a bit more.
If memory serves me it's to disable the cars electrics during delivery and is disabled during the dealers PDI. From then on it's main purpose is to confuse the curious |
Mudplugger Member Since: 20 Feb 2009 Location: err... near Inglewhite, Lancs. Posts: 95 ![]() ![]() ![]() |
This had always had me curious too. So post PDI is it correct to say it has NO function?
Are you mad? For all we know you might end time and stop the Universe!
Thanks for that folks. Funny thing to have in such an accessible place. Mind you, it did take me 15 months to spot it in the first place I suppose!! |
Thanks for the extra info. Any knowledge of these things much appreciated.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
Mine doesn't have this switch under the sterring column. (06MY) Discovery 4 HSE
BBS SPY Member Since: 20 Apr 2009 Location: Limassol Posts: 101 ![]() ![]() ![]() |
I believe it was only the later more fully CAN bus vehicles that had it. Not sure if they still have the Pyro Isolater fitted, which can, by control from the Airbag ECU, explosively disconnect the positive battery Lead. |
The poster's vehicle is the same age as mine though so that doesn't make sense. Discovery 4 HSE
Diesel L322's did not get converted to CAN BUS until the introduction of the TDV8, with the exception of the entire infotainment system which was fitted from 2005 on to all models and is is all linked together by the MOST fiber optic bus. Therefore a 2006 Petrol is mainly CAN and a 2006 Diesel mainly BMW.
Nice clarification!
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 789 ![]() ![]() ![]() |
Can someone explain what is the use of the funny shaped hole near the lamp (the circled one)? It doesn't seem to have any visible purpose...
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 773 ![]() ![]() ![]() |
RRVSE - I found this switch some time ago (took me just less than a year! |
The buzzer/gong goes in there:
