Home > Maintenance & Mods (L322) > Is this steering fluid ok? |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 541 |
Well, considering it's a nice pink when it's new I'd say that's well and truly had it! Drives:
8th Mar 2019 11:51am |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
I think so too.
8th Mar 2019 1:43pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
9th Mar 2019 8:21am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
I'm not sure about the 2010MY but the cold climate fluid that's spec'd for my 2009MY is luminous green rather than pink? 2016 Skoda Octavia VRS Estate
9th Mar 2019 9:22am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
The PAS fluid is GREEN NOT PINK gents...
9th Mar 2019 9:46am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Merhaba Umitbat, I posted PAS fluid change using vacuum, is is quick and easy. I use Pentosin CHF 202.
9th Mar 2019 10:48am |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Is there not a drain plug, or maybe a union you can loosen to drain away the fluid then refil , seems to be a bit of a faff on with suction and the like , just a thought |
9th Mar 2019 11:28am |
Merhaba:) Great posts thanks. I will find the right fluid first then go for it!! U did one cycle and it is ok right? Emirates did many... 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
9th Mar 2019 9:15pm |
If you use my method you will flush the system and have only new fluid in the system. it will take cc 2 liters of fluid. 2012 TDV8 Black Edition
10th Mar 2019 3:39am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Out of curiosity today I had a look at the power steering fluid in my car, it's a golden yellow colour. It appears in good condition and certainly doesn't smell untoward. As far as I am aware the steering is working correctly and has never been a cause of concern. Am I correct in assuming I would have to flush out the entire system rather than simply emptying the reservoir ie not mixing the "correct" new green fluid with old.
11th Mar 2019 8:06pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
My local indy disconnected the rack pipe to drain the lot far easier then reffill and bleed cost me £70 _____________________________________________________
12th Mar 2019 10:23am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Had mine flushed this week. We used this:
25th Jun 2021 9:24am |
