Home > Maintenance & Mods (L322) > Is this steering fluid ok?
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Our mechanic said this fluid ok where another one said it is bad.
I think it is bad too.
What do u think?
There is slight buzz when turning rhe steering wheel.
 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #507949 8th Mar 2019 11:18am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Well, considering it's a nice pink when it's new I'd say that's well and truly had it! Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #507955 8th Mar 2019 11:51am
umitbat
I think so too.
How could LR mechanic can say thats ok i dont get... 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #507967 8th Mar 2019 1:43pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
umitbat
The fist time doing this job.
with our cars - with the car standing / not running - I tend to use my workshop suction tube bottle and suck all the fluid out - till it reaches the gauze at the base - then fill back up with NEW fluid.
The fluid when new is bright PINK.
I run the car for a day - then do it all again:
suction tube and suck all the fluid out till it reaches the gauze at the base - then fill back up with NEW fluid.
I run the car for a second day - then do it all again:
after 4 fill ups - THEN THE WHOLE SYSTEM has been flushed - to get rid of all the old stuff.
Note:
The power steering fluid will only circulate when the engine is running and theirs slight pressure on the steering wheel - this causes a valve in the pump to open and circulate the fluid around !
Note: - Do not over fill the system !
Once you have clear bright PINK power steering fluid in the reservoir -
Then every 4 months I suck out the fluid again to the lower of the reservoir gauze then refill with brand new fluid.
It's very cheap to buy - but ensure you buy the right one and hi grade power steering fluid - that was you will ensure your power steering pump is in mint condition.
After all - all oils for the FF - are cheap in comparison to how much the car was :-
YOU CARS ONLY AS GOOD AS THE SERVICE & ATTENTION & CARE SHE GETS
[/i]
Post #508051 9th Mar 2019 8:21am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I'm not sure about the 2010MY but the cold climate fluid that's spec'd for my 2009MY is luminous green rather than pink? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #508057 9th Mar 2019 9:22am
The PAS fluid is GREEN NOT PINK gents...
And imho that fluid in your car is finished sir and needs replacing! 👍
Post #508062 9th Mar 2019 9:46am
nino_nino
Merhaba Umitbat, I posted PAS fluid change using vacuum, is is quick and easy. I use Pentosin CHF 202.
https://www.fullfatrr.com/forum/topic47852.html 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #508068 9th Mar 2019 10:48am
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Is there not a drain plug, or maybe a union you can loosen to drain away the fluid then refil , seems to be a bit of a faff on with suction and the like , just a thought Thumbs Up
Post #508070 9th Mar 2019 11:28am
umitbat
Merhaba:)
Great posts thanks.
I will find the right fluid first then go for it!!
U did one cycle and it is ok right?
Emirates did many... 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #508131 9th Mar 2019 9:15pm
nino_nino
If you use my method you will flush the system and have only new fluid in the system. it will take cc 2 liters of fluid. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #508144 10th Mar 2019 3:39am
Out of curiosity today I had a look at the power steering fluid in my car, it's a golden yellow colour. It appears in good condition and certainly doesn't smell untoward. As far as I am aware the steering is working correctly and has never been a cause of concern. Am I correct in assuming I would have to flush out the entire system rather than simply emptying the reservoir ie not mixing the "correct" new green fluid with old.
Investigating the colour it seems this is just a manufacturer thing for identification purposes and doesn't in anyway affect the fluids properties, for example Mercedes use a gold coloured fluid.
Post #508338 11th Mar 2019 8:06pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
My local indy disconnected the rack pipe to drain the lot far easier then reffill and bleed cost me £70 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #508395 12th Mar 2019 10:23am
DrRob
Had mine flushed this week. We used this:
https://www.advancedfactors.co.uk/adv906-0...5443-p.asp
Nice green colour now in the reservoir not some horrible brown Censored
4L needed as per WM Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #598693 25th Jun 2021 9:24am
