![]() | Home > In Car Electronics (L322) > Speedo to km |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35532 ![]() ![]() |
GAP produce a diagnostic tool that can adjust the heights, clear faults , configure the ccf and loads more..
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
https://www.gap-diagnostic.com/ Current: 2011 FFRR Vogue SE 4.4 TDV8
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
Didn't I read somewhere it changes depending on where the gps says it is? Current: RR L322 2010
nope, doesnt do that.. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4326 ![]() ![]() ![]() |
Stan I want to add the mph digital box - can you remember where this is in the IID menu? TIA Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
rob,
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Sorted!
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 410 ![]() ![]() ![]() |
After getting her back from the paint shop, I checked and only KM reference my speedo makes is within the small square box providing the digital speed reading. The gauge does not change. |
You should be able to change the dial from the dash menu Current: 2011 FFRR Vogue SE 4.4 TDV8
sorry for double posting. can you see the box I mean? |
Yes -- if you want the dial in km/h you can change that in the dash menu -- use the menu button then Display Settings -- you'll be able to change the temperature displayed between C and F too Current: 2011 FFRR Vogue SE 4.4 TDV8
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
If you have an IID tool it's from Gap I did mine in the scuttle to France I think its configure section? |
Hi tommy
Interesting SFM, my mechanic advised she'd fail on the current tourist mode.
