Home > In Car Electronics (L322) > Speedo to km
Page 2 of 3 <123>
GAP produce a diagnostic tool that can adjust the heights, clear faults , configure the ccf and loads more..
an informative thread here, [plus lots more on the forum]
https://www.fullfatrr.com/forum/topic12418.html
can be bought here,
https://www.fullfatrr.com/forum/topic47809.html
its highly recommended that every FF should have one...
Post #506712 28th Feb 2019 4:22pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
https://www.gap-diagnostic.com/ Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #506714 28th Feb 2019 4:37pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Thanks Stan
I will do that, but the bloody internet s gone down again!
The joys of rural France.
Thanks again on the sat-Nav issue.
Working fine now
Post #506715 28th Feb 2019 4:38pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Didn't I read somewhere it changes depending on where the gps says it is? Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #506751 28th Feb 2019 9:48pm
nope, doesnt do that..
Post #506754 28th Feb 2019 9:52pm
DrRob
stan wrote:
that is weird...
i've configured my digital box to stay on mph using the GAP iidtool otherwise it would be the same as the large dial ...
Stan
I want to add the mph digital box - can you remember where this is in the IID menu?
TIA
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #506786 1st Mar 2019 8:07am
rob,
IPC-instrument pack
digital speed
display...
Post #506792 1st Mar 2019 8:34am
SFM
Sorted!
Cheers Stan
Post #507088 2nd Mar 2019 11:44pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
After getting her back from the paint shop, I checked and only KM reference my speedo makes is within the small square box providing the digital speed reading. The gauge does not change.
Post #507792 7th Mar 2019 2:55pm
Bushy30
You should be able to change the dial from the dash menu Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #507795 7th Mar 2019 3:09pm
TDV8_Tommy
sorry for double posting.
can you see the box I mean?
Post #507798 7th Mar 2019 3:10pm
Bushy30
Yes -- if you want the dial in km/h you can change that in the dash menu -- use the menu button then Display Settings -- you'll be able to change the temperature displayed between C and F too Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #507802 7th Mar 2019 3:16pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
If you have an IID tool it's from Gap I did mine in the scuttle to France I think its configure section?
Post #507809 7th Mar 2019 3:39pm
SFM
Hi tommy
I tried several times but only got the little box like you have.
Got another license on my iid tool, and managed to change it with that.
Car passed its French MOT today, headlamps were ok with just the tourist mode, thank god!
Post #507810 7th Mar 2019 3:42pm
TDV8_Tommy
Interesting SFM, my mechanic advised she'd fail on the current tourist mode.
Good for you! big expense spared.
I've no plans to register here yet.
Post #507811 7th Mar 2019 3:44pm
Page 2 of 3 <123>
