Home > Technical (L322) > Fbh fuse
dazza1983
Fbh fuse
Anyone know what fuse to pull to reset fbh?
I’ve read some post about fuse no 59 but then people say 59 is spare fuse?
Checked the manual and cant see anything either fuse 19 says engine control module?
Daz
Post #507346 4th Mar 2019 8:05pm
mjdronfield
It’s this to reset it for pairing a remote, if that’s what you are after....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #507352 4th Mar 2019 8:33pm
dazza1983
my remote is paired, i believe my fbh has failed to strat 3 times so now needs resetting
Daz
Post #507353 4th Mar 2019 8:36pm
mjdronfield
Ah right.... not sure then.
It may be same fuse? But no proof.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #507359 4th Mar 2019 8:54pm
rjff
You have a PM.
Try battery junction box, fuse FL8B.
From workshop manual:
Reset procedure is stated as LR diagnostics to reset or disconnect battery power supply for at least 10seconds Cheers
Richard
Gap IIDBT
Post #507363 4th Mar 2019 9:18pm
dazza1983
my battery was disconnected for some time last friday whilst i was fitting my deployable side steps, so would i be wasting my time trying to pull a fuse for the fbh? Would the battery disconnection reset everything anywyas?
Daz
Post #507364 4th Mar 2019 9:25pm
dazza1983
well this things deffo crazy, ive been playing with it in the cold lol, and at one point i got a whiff of diesel, had a loud click towards the rear of the car which was really odd?
then it sounded like it was firing but not sure the fan went super loud and faster than ive heard it before
its nuts this thing just want it to work lol
Post #507371 4th Mar 2019 9:46pm
rjff
Bat Censored t crazy.
Sounds like the fuse doesn't need to be pulled.
The click at the rear should be the FBH pump working and it should continue clicking whilst the FBH works. I think the heater fan goes on, the unit fan starts and the unit fires up. That seems on mine to give two levels of noise. Cheers
Richard
Gap IIDBT
Post #507376 4th Mar 2019 10:03pm
dazza1983
I just had a real quick look with a head torch on lol and before typically the heavens opened up and whilst i was disconnecting the battery last friday to fit my steps i remember seeing a loose electrical connection plug?
I wonder if this has anything to do with it? Or does the fact that the fans work indicate that its all plugged in ok?
Daz.
Post #507382 4th Mar 2019 10:08pm
rjff
If you can stick up a pic when it's daylight, someone may be able to identify it. Particularly if you can find the other part it fits into and a quick description of its location also helps, as much as you can. Cheers
Richard
Gap IIDBT
Post #507388 4th Mar 2019 10:22pm
dazza1983
This little plug seems to have like a plastic spade blanking connection that it connects to, however i cannot remember if i did this on friday when i spotted the wire or if they are suppose to mate with each other?
 Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #507394 4th Mar 2019 10:33pm
rjff
I think BB Mike has beaten us to it. Cheers
Richard
Gap IIDBT
Post #507411 4th Mar 2019 11:13pm
Sonearly
Please tell me what this connector is for, is it anything to do with the FBH ?
I also have spent hours trying to pair a remote for the FBH
Have tried everything, pulling fuse, disconnecting transceiver, disconnecting battery, hard rest, alas with no result.
I too have found this connector and now know where it goes, hoping it is the final piece of the puzzle
Post #575602 9th Dec 2020 11:34pm
rjff
Can't recall what the connector is for, but it could be the one for transportation which is disconnected prior to first sale.
On the FBH, can you give the model no on the receiver in the boot cubby and the remote, and a pic of each may help. They may not pair if not compatable.
Also what lights and colours are you getting on the remote's LED? And being cheeky, Smile have you looked at the workshop manual in the wiki, there's good detail on the FBH and paring. May help.
If this doesn't help, someone with more knowledge will be along soon. Cheers
Richard
Gap IIDBT
Post #575631 10th Dec 2020 11:47am
Sonearly
Thanks for reply.
When I try to sync via the off button, it turns green followed by flashing red lights.
I have attach pics as requested
Post #575647 10th Dec 2020 2:39pm
