Home > Wheels & Tyres > Tyre sizes |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1419 |
Lots of L322 owners switch to the 55 profile and actually its more accurate speedometer wise than the 50's 2021 D350 Fifty Edition - Carpathian Grey
28th Feb 2019 8:56pm |
This will help to compare sizes
28th Feb 2019 8:59pm |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 201 |
Probably because the speedo deliberately overreads. Mine is set to 2MPH IIRC from the CCF. Current: RR L322 2010 Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB |
28th Feb 2019 9:45pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
As above - the 255 55 20 are a standard size on the L405 so are readily available and cheaper than 255 50 20's - so quite a few people have fitted them to L322's with no problems at all. |
28th Feb 2019 10:44pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1382 |
My 2012 WM latterly had Goodyear 255/55R20 on 405 style 502 wheels. No problems as regards fit/rubbing. Speedo was almost exactly accurate per Road Angel Gem device, almost to the point of under-reading. Steering a bit slower than the 255/50R20 standard size. Ride quality will vary depending on tread design etc - the standard Continentals have soft sidewalls and so ride a bit softer than all terrains like the AT3 (or Goodyear Duratrac which I use in winter). Only Range Rovers since 1988 |
1st Mar 2019 11:43am |
